Thread: BallNuts, 1,2 or a double.
IME none mix n match well unless coming from same company and then depends how old.? Tooling changes etc make difference to screws/nuts.
For instance I've got some Old screws from China and decided to replace worn nuts from same supplier and the current nuts supplied while fitting were not a very good fit and needed larger balls. They Worked but not straight fit and needed tweaking.
Regards best way then I think is double nuts with springs washers but like robin says it comes with a price, thats being a royal pain to fit and get right also IMO slightly more wear due to higher constant friction.
Shimmed Double nuts are ok but they need servicing occasionally, which shouldn't really be a problem as it's a good idea, esp on lathe, to have strip down every 12-18months or so to give a good clean and fettleing.!Last edited by JAZZCNC; 04-01-2015 at 03:20 PM.
04-01-2015 #2
04-01-2015 #3
Stuart,
I did this a while ago so trying to remember the exact figure. Around 0.05mm (50 microns) from memory based on a 16mm diameter 5mm pitch chinese ballscrew and single nut. Measured this using a DTI on the Y axis and jogging it from Mach3 back and forth in 0.01mm steps.
1605 ballnuts
By dudz in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 30-03-2013, 09:31 AM -
Securing and Aligning Ballnuts
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 29-09-2012, 11:39 PM -
Ballnuts
By Web Goblin in forum General DiscussionReplies: 19Last Post: 04-08-2011, 11:28 AM -
Single or double??
By Wobblybootie in forum General DiscussionReplies: 7Last Post: 06-01-2011, 08:08 PM -
What oil for ballnuts?
By Robin Hewitt in forum General DiscussionReplies: 1Last Post: 24-10-2009, 08:36 PM
