    So after my giant router build the next thing on the list to think about is a way to chop the large blocks of eps up into usably pices which is normally just smaller blocks so a horizontal and vertical cut however it would allso be nice to have two and Possably four axis cnc posabilities in the future.
    the blocks I cut range from 8'x4'x4' to 16'x4'x4' but normally 16x4x2 and weight about 70-80kg
    the he machine is going to have to go in the shed were I store the blocks at the moment so restricted a bit by size
    I'm not after super accuracy just a nice straight line that can be set up in minimal time and keeping costs as low as posable. I'm wondering if to start with rather than having it cnc I can just have it motorised and controlled by a simple switch or something to give a constant feed rate.
    The first thing I have been trying to deside on is what liniar motion components to use. For this as nice as it would be to use Hiwin rails I'm hoping I can come up with a suitable and cheaper method with the 6meter long axis at least possibly something along the lines of the cnc router parts method of using barring and flat steal plate ( I will put a link to when I'm on a pc)
    I have seen a few similar machines which has given me a few ideas some quite minimal and some a bit more substantial but yet to deside on how to do it myself.
  1. BUILD LOG: Giant 20' x 3' x 2' router build
    By charlieuk in forum DIY Router Build Logs
    Last Post: 17-02-2016, 06:39 PM
  2. CNC hot wire cutter
    By Nstocks in forum Machine Discussion
    Last Post: 22-05-2014, 07:54 PM
  3. How to Wire this Sensor
    Last Post: 26-11-2013, 05:09 PM
  4. Wire.. Oh why so many types....
    By BedlamRik in forum General Electronics
    Last Post: 05-01-2013, 01:05 AM
  5. NEW MEMBER: First post - want to build a cnc hot wire foam cutter
    By rckeith in forum New Member Introductions
    Last Post: 12-12-2010, 12:23 AM
