    Hi there,
    I have the Proxxon Die-Cast Alluminium X-Y Table and am looking at spindles. The plan is to get it going and then CNC it later.
    Does anybody have experience of the Proxxon BFW 40/E spindle (900-6000rpm) ? or would i be better going for one of the Kress spindles? if so which one? plan to be machining plastics and ally.
    I do like the look of the DC motor spindles seen elsewhere on this forum and may give that a go later
    cheers for now
    Snow
    BFW can achieve low RPM but is limited at 6000 RPM. Kress can achieve 29000 RPM but it cannot go lower then 10000 RPM (5000 RPM on their slightly more expensive 1050 FME-1).
    BFW is quite silent as it won't reach a high RPM. Kress is ok at its minimum 10000 RPM but it gets noisy quickly as you bump up at the RPM.
    BFW torque is quite low, it doesn't take much to stall the motor - that doesn't mean you can't successfully take _very_ shallow passes in aluminium and soft steel to complete your job. You might hear Kress slightly slowing down during heavy cuts, but it won't stall - not a good thing either, if your feedrate was planned for a specific RPM.
    BFW will come with up to 6mm collets only, while you can get up to 10mm collets for Kress, both proprietary format, not matching something like the ER standard.
    BFW is slightly lighter then the Kress, but not much. They are both 43mm collar.
    Overall I would definitely go for Kress for a CNC machine, BFW is more of a toy and it will work better with a toy mill like the KT150 combo purposed by Proxxon. However there are better choices in the price range, such as the 0.8kW chinese spindles.
    Thanks Trispectiv,
    I think i'll probably go for the Kress then. I was kind of maybe leaning to the Proxxon one but the Kress will probably be more useful once i almost inevitably decide that i'm wasting my time and should just get a proper machine
  1. Replies: 0
    Last Post: 13-11-2013, 06:50 PM
  2. Replies: 0
    Last Post: 12-11-2013, 10:36 AM
  3. Designing a Metal milling bushless Spindle
    By Kevman in forum Electronic Project Building
    Last Post: 14-04-2013, 05:43 PM
  4. Can anyone recommend a spindle for milling PCB and cast acrylic?
    Last Post: 11-10-2011, 07:54 PM
  5. FOR SALE: Mini Mill spindle motor + controller etc
    By pjm in forum Items For Sale
    Last Post: 22-06-2010, 06:34 AM
