Page 1 of 3 123 LastLast
    Well not at all what I was expecting! I was talking to a friend about a build and the conversation has ended up with me adopting a partially completed build.
    The machine was started as a project by a precision engineer friend and has been abandoned because of lack of time and his moving overseas for work... I still find it hard to believe he is allowing me to play with it.
    Not much detail yet, I am still waiting for the original drawings so I know what the partially finished parts are for and what machining is still needed...but collected a few bits last week.... probably 350kg of them...
    A pallet full of parts, some machined, some partially machined and some waterjetted.... the visible ballscrews are x axis and 32mm!!!
Name:	2015-01-16 15.12.24.jpg
ID:	14439   Click image for larger version.
Name:	2015-01-16 15.12.47.jpg
    30mm hiwin x rails, 20mm for y &Z
    most of the frame is 30mm aluminium... gantry is extrusion, sixes to follow
    everything except the BOB in the electrics... servos and controlers etc...
    2kw watercooled spindle
    extruded aluminium table
    Hoping to start work on it next week... far sooner than I would have chosen and still far too many basics to learn.. but we will have some fun along the way
Name:	2015-01-16 15.17.08.jpg
ID:	14441   Click image for larger version.
Name:	2015-01-16 15.18.06.jpg
ID:	14442   Click image for larger version.
Name:	2015-01-16 15.12.12.jpg
    And I thought Christmas was in December!!! Good luck with the rest of it. G.
    By the sound of those parts it's going to be big and a beast when completed, very good deal.
    Unfortunately I am building it for them... but good experience, and I will be able to use it... I hate to think what it cost so far as they are genuine hiwin and quality screws...oh, and I get paid pocket money too
    I think it is about 2 by 1.5m "externally "
    Got a little bit done this week, finding it helping with my rehabilitation as I need to use both hands for most of it
    28 m16x50 holes tapped, 48 m8 tapped holes for the rails, all by hand as the company that did the original machining "forgot"... thanks for that
    test assembly... I now know the approximate size is 2m x 1.1m between rails, and first problem... one of the cross rails is drilled about 2mm out, still thinking on how to best fix that, any suggestions gratefully recieved
    nice chunky assembly, 160x30mm plate
Name:	2015-01-22 09.43.47.jpg
ID:	14498   Click image for larger version.
Name:	2015-01-23 15.28.21.jpg
ID:	14501   Click image for larger version.
Name:	2015-01-23 14.59.52.jpg
ID:	14500   Click image for larger version.
Name:	2015-01-23 15.28.42.jpg
    Interesting machine
    The cross rail being drilled about 2mm out- if I understand correctly then I think you need to slot the through hole. If you don't have a mill then you may be able to use a router and carbide bit or pillar drill with counterbore bit plus some filing.
    Interesting machine
    not an ideal solution, but I think it will be adequate, there is a 3rd bolt for each end from underneath so plenty of fixing, and the counterbores are going to be covered at some point with something to keep the ballscrews and rails clean
    What about filling the holes with stuff then drill new holes.
    https://www.machinemart.co.uk/shop/p...inium%20repair
    I would worry doing it that way eddy, as the new hole would mainly be in the filler... and is 50mm deep
    only alternative is to drill out to about 24mm tap & plug, pin it and then redrill & tap.... but holding this vertically to drill will be a right pain.
    think it will end up on the inside and ream holes to suit in the side rails
  1. Router build
    Last Post: 18-12-2014, 07:19 PM
  2. Does anyone want to build me a cnc router?
  4. BUILD LOG: My Router Build!
    By andy0202 in forum DIY Router Build Logs
    Last Post: 31-01-2013, 08:51 AM
  5. BUILD LOG: A3 Router Build
