Thread: twin drive
    can any advise on where to purchase drive sprockets and idler sprockets (2 x drive m10, 2 x idler m10, 1 x drive m8) to convert to m10 threaded twin drive (im getting twist on a centered single drive) this is a prototype im working on so im not going to be putting anything other than threaded rod for the drives
    Quote Originally Posted by universally View Post
    Do you want to drive chains, belts, other ?
    im thinkin belts and pullies after some research
  5. The Following User Says Thank You to EddyCurrent For This Useful Post:
  6. #5
    Thanks for posting the links Eddy as I was looking for them, what's the smallest number of teeth to use on the pulleys to be safe ? I've read some where with a small number of teeth there's more chance for the belt to jump the teeth and cause problems with racking.
    Mike :)
  7. #6
    Quote Originally Posted by longy View Post
    Mike :)
    6 teeth in mesh is minimum for all pulleys. Means all specs on the sheets are for that particular case.
    The best belt calculator i have found
    thanks :) found just what i needed :)
  1. Setup for squaring twin X-axis gantry
    By routercnc in forum Gantry/Router Machines & Building
    Last Post: 26-03-2014, 10:13 PM
  2. FOR SALE: AXYZ 6012 - 4mtr x 2mtr Twin Head CNC FOR SALE
    By daverowland in forum Items For Sale
    Last Post: 28-06-2013, 05:18 PM
  3. RFQ: Delrin drive nut (lee)
    By progomez in forum Projects, Jobs & Requests
    Last Post: 14-10-2009, 09:00 PM
  4. Twin ball screw drive on X - configuration question
    By HiltonSteve in forum Gantry/Router Machines & Building
    Last Post: 20-05-2009, 10:13 PM
  5. Twin X axis Drives
    By Hobbit in forum Gantry/Router Machines & Building
    Last Post: 20-02-2009, 07:22 AM
