    Hi Chaps.
    any suggestions on good manufacturers of router bits, mainly for carving text v carving
    or suggestions on makes to avoid?
    will only be using softwoods and maybe plastics
    thanks guys
    Quote Originally Posted by totally useless View Post
    Hi Chaps.
    thanks guys
    Have a look through these; http://www.mycncuk.com/threads/8222-...4867#post64867
  3. The Following User Says Thank You to EddyCurrent For This Useful Post:
    Thanks Eddy
  5. #4
    Oertli, they are the rolls Royce off cutters but come with a price
  6. #5
    Cheers malenko
    i will take a look
  7. Did you manage to source these? I can maybe help you with the exact types of routers you may need, what are the exact materials you are using them on?
  8. #7
    Hi JMack
    i have purchased a few from ebay {china} to practice with, {cnc not built yet} but will require some decent bits when up and running. i am mostly going to be using ...MDF...SOFT PLYWOOD...HARDWOODS....i will be doing a lot of text, and i want to carve out images dogs..boats... so i am presuming 60-90-120 degree v carve bits. Not sure on what other bits do really? end mill bits? up cut..down cut 1 flute 2 flute 3 flute what's all that about??? but any advice is very welcome and much appreciated. Thanks..Pete
  9. Hi,
    For the soft wood types if you can achieve high feed rates then High Speed Steel O Flute Straight Router Bits are great. They combine an open flute design with single flute geometry to provide optimum chip removal. Also great for hand fed operations.
    For hard wood High speed steel V Flute Straight Router Bits can be good if you need to a smooth finish with a balanced tool.
    However there are also some great tools for both soft wood and hard wood such as upcut or downcut double flute high speed steel router bits for excellent finish over single flute. Use downcut if you want to protect the finish on the top of the workpiece however downcut if not. You can move onto Carbide if you need longer tool life or rigidity.
    If you need help finding these Pete just send me a direct message and I will be happy to help!
  1. Router bits for use with Slate
    By habibuzziwa in forum Tool & Tooling Technology
    Last Post: 30-06-2013, 05:12 PM
  2. 3.175mm router bits
    By ian stenson in forum Tool & Tooling Technology
    Last Post: 13-06-2013, 06:59 AM
  3. FOR SALE: Selling all my 2mt x 1.2mt CNC router bits...
    By fasteddy in forum Items For Sale
    Last Post: 11-04-2013, 05:32 PM
  4. SWAP: 6mm Carbide CNC Router Bits for 3mm's
    By Fivetide in forum Items For Swap
    Last Post: 04-12-2012, 03:47 PM
  5. CNC Router Bits
    By ploughex in forum Milling Machines, Builds & Conversions
    Last Post: 01-08-2010, 05:26 PM
