  1. #31
    Kendrick, I do not think your spindle is DC,
    Easy to check Kendrick just take the connector off the spindle and if it as 2 wires it's DC, 3 wires it will be VFD/3phase like Geoffrey says. Looking at your other post I agree with Geoffrey it looks like VFD control panel.
  2. #32
    Fr the power problems with the usb what about a powered hub then the usb power is not coming from the laptop.
    The spindle has 4 pins coming off it more than I would expect from DC maybe brushless with a backemf sensor wire.
    kendrick
  3. #33
    Quote Originally Posted by Kendrick57 View Post
    kendrick
    See in this other thread; http://www.mycncuk.com/threads/8457-...7150#post67150 too many threads for same thing.
  4. #34
    kendrick
    Kendrick, you DO NOT have a DC spindle. G.
  5. #35
    Your Correct no point having 2 threads open for the same Cnc. This threads problems have now been sorted, can any future comments be passed to a more generalised thread about any problems I have with the 6040. Go to
    http://www.mycncuk.com/threads/8457-...7115#post67115
    kendrick
  6. #36
    kendrick
    the 4th pin will be earth or not even connected ..Clive
  7. #37
    I have a UC300 which I've used with Mach3 and was better than just the parallel port on the PC. I now use it with UCCNC and it's another big step up from using it with Mach3. UCCNC and UC300 are designed for each other, with Mach3 you're relying on a third party plugin sitting between Mach3 and the hardware. UC300 is a good option if like me you want to add more sensors like probes and FR override control. The other advantage is you can move beyond WinXP/7 on your controller PC which when you also use it for running Vectric software is a huge advantage. Running mine on a Win10 machine and it's as happy as Larry.
  1. USB TO Parallel Port DIY Interface
    By Lee Roberts in forum Electronic Project Building
    Last Post: 17-02-2018, 06:46 PM
  2. breakout board usb or parallel
    By crossleymarko in forum Motor Drivers & Controllers
    Last Post: 30-07-2013, 11:44 AM
  3. PCI parallel card / BOB
    By artmin in forum Computer Hardware
    Last Post: 30-01-2012, 03:38 PM
  4. parallel port address
    By Dan Brown in forum Artsoft Mach
    Last Post: 07-01-2010, 11:04 AM
