21-02-2015 #31
21-02-2015 #32
Fr the power problems with the usb what about a powered hub then the usb power is not coming from the laptop.
The spindle has 4 pins coming off it more than I would expect from DC maybe brushless with a backemf sensor wire.
kendrick
21-02-2015 #33
See in this other thread; http://www.mycncuk.com/threads/8457-...7150#post67150 too many threads for same thing.
21-02-2015 #34
21-02-2015 #35
Your Correct no point having 2 threads open for the same Cnc. This threads problems have now been sorted, can any future comments be passed to a more generalised thread about any problems I have with the 6040. Go to
http://www.mycncuk.com/threads/8457-...7115#post67115
kendrick
21-02-2015 #36
07-10-2015 #37
I have a UC300 which I've used with Mach3 and was better than just the parallel port on the PC. I now use it with UCCNC and it's another big step up from using it with Mach3. UCCNC and UC300 are designed for each other, with Mach3 you're relying on a third party plugin sitting between Mach3 and the hardware. UC300 is a good option if like me you want to add more sensors like probes and FR override control. The other advantage is you can move beyond WinXP/7 on your controller PC which when you also use it for running Vectric software is a huge advantage. Running mine on a Win10 machine and it's as happy as Larry.
05-01-2020 #38
Can you run a UC100 with t2 laser/CNC Software? I can't get it to comunicate wih the USB on my notebook pc! Please Help.
Thanks in advance!
05-01-2020 #39
05-01-2020 #40
Thanks, I tried hard to get it to work! Would you buy Mach3 Mach4, or UCCNC Software? I would like to run it unders windows 10 ona newer P.C!
Thanks again for your help!
Tom Megna
USB TO Parallel Port DIY Interface
By Lee Roberts in forum Electronic Project BuildingReplies: 42Last Post: 17-02-2018, 07:46 PM -
breakout board usb or parallel
By crossleymarko in forum Motor Drivers & ControllersReplies: 13Last Post: 30-07-2013, 12:44 PM -
PCI parallel card / BOB
By artmin in forum Computer HardwareReplies: 11Last Post: 30-01-2012, 04:38 PM -
parallel port address
By Dan Brown in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 07-01-2010, 12:04 PM
