    Hi
    i'm starting a thread or more likely the step by step way I've built my own removable water bath for the bed of my Cnc so that I can cut carbon fiber without half of the dust going up my nostrils.
    I got the idea from a YouTube video of a diy water bath that was being used to cut carbon fiber sheet. I decided to do somthing very similar.
    first a list of parts:-
    clear polycarbonate 60 x 460 x 10 mm this is the biggest size I could fit on my cutting bed
    4 lengths of angle aluminium cut to size as big as I could fit(I messed up here I bought 50 x 20 mm aluminium only to find it hit the spindle so I am at the moment cutting 10 mm off the 50mm side with the Cnc a very slow process as I only have 2 mm bits but it is getting there)
    epoxy glue and silicone sealant
    m8 bolts and nuts to hold the bed secure and m6 to hold the carbon in the water bath
    a small external fishtank pump and 2 m of tubeing (to empty the water bath with)
    the first thing to do was alter the height of the aluminium at the speed I am doing that it will take about a day. The first side is just finishing as I type this post.
    kendrick
    Looks like I must bring this thread to an end just as it started.
    although there is a video on YouTube of this being done according to the manufacturer of the carbon I will be cutting water and carbon are not a good mix I will go down the enclosure vacuum route.
    Kendrick
  1. FOR SALE: Carbon Fibre Sheet 2mm (all carbon 3k)
    By richie00boy in forum Items For Sale
    Last Post: 27-02-2015, 07:44 PM
  2. RFQ: Composite flat sheet cutting. (Water jet or router)
    By carboncactus in forum Projects, Jobs & Requests
    Last Post: 05-08-2013, 07:31 PM
  3. NEW MEMBER: Seeking advice on a CNC setup for (one off) machining carbon fiber plate
    By Tomcat in forum New Member Introductions
    Last Post: 03-03-2013, 12:43 PM
  4. Which of these bits for carbon fiber and fiber glass?
    By craigrobbo in forum Tool & Tooling Technology
    Last Post: 28-02-2013, 12:03 AM
  5. Carbon fiber keyrings...
    By Jonathan in forum General Discussion
    Last Post: 08-03-2011, 01:39 PM
