    I see they have a NEMA34 3.5Nm Hybrid stepper on special offer at £34.95 inluding tax
    I could use that if I sawed the shaft off the back.
    Unfortunately there is no torque/speed curve, what a surprise, so you can't tell if it's a wonderful thing or a total lemon.
    They don't have a contact email so you can't ask for more info, OTOH, at that price I suppose I could suck one and see.
    Can't decide.
    Should I be bothered? I mean they're not exactly trying. Maybe I should wait until it arrives in "Clearance bargains", then 'phone and negotiate for 3
    Robin
    Because as Gary says it all depends on what driver and what power supply you use.
    If someone does publish a torque speed curve then how do you know it's for that motor? You buy it and how can the average Joe test it ?
    John S -
    You're right, I have to wait until Gary has the equivalent Changzhou motor back in stock. Any data is better than no data
  4. Buy it, the price is good, and the current is the same as the ones we do, so they should perform about the same.
    It will be 3A in series and 6A in parallel.
    Quote Originally Posted by Gary View Post
    Buy it
    Yes Sir, I bought 3 Sir, got free shipping Sir
    Cost me £91.17 after I knock the VAT off what I owe darling Alistaire.
    I'll let you know if it was a bargain when I find out how fast they can turn my little handles before clacking out
  6. Quote Originally Posted by Robin Hewitt View Post
    What are you going to use them on, Robin? I'm wondering if i should get a set too on the anticipation of CNC'ing my mill.... even tho that might be a year away.... but the price looks good and I'm sure they wont get cheaper (as a rule)
    On the X3 kits we used to do we used the type 23's triple stack 312 oz/ in ? driving 5mm screws direct.
    Running on the big drives at 72 volts we were getting between 2000mm/min and 2500mm/min in rapids so in mm/sec that's 33mm/s to 42mm/s
    However that's far too fast for a machine this size and we used to modify the XML so they maxed out at 1500mm/min in X and Y and 1200 mm/min in Z
    On the test machine we nearly got 4000mm / min in X before loosing steps, this was just done to see where the limits were and not dick slapping.
    Often times you can get more speed out of smaller motors than larger because of the initial acceleration.
    I have a big rotary table powered by a 42 stepper and it crawls round in comparison to my 6" table. On the last Bridgeport BOSS1 I have done I took the original type 42's off, rated at 1100 oz/in and replaced them with 34's rated at 920 oz/in and the speed nearly doubled because of the efficiency of the newer squarer motors and better magnets than the old outdated round ones.
    John S -
    I currently use a 16t:40t pulley combination with a 1.2Nm motor.
    The 5:2 reduction gave me a convenient 200 half steps/mm.
    The gutsier motor should allow me a 5:4 reduction thus halving the motor speed and keeping me in the motor torque band, hopefully.
    The screws have just under 10um backlash so a 10um half step may be the way to go, approx 0.0004".
    I could go for a whacky step resolution, all the software does is take the required X, Y, Z in millimeters, multiply by steps per mm, round it to an integer and off it goes. Any value for steps/mm is okay, I just change the SPM variable, recompile it and everything sorts itself out. The only thing I would lose is convenient cogging on the handle dials.
    I cut the cheeks for the Z axis yesterday and it came out oversize, everything bent under the tool side pressure when I removed the last 0.5mm on the finishing pass. I got +35um in the X and +55um in the Y, give or take 10um. Probably would have got a lot better if I'd repeated the pass. This is so much better than before I changed screws, it used to be that within 200um was a good day
  1. Replies: 1
  2. Arc Eurotrade Sieg X2
    By Rogue in forum Marketplace Discussion
    Last Post: 01-08-2013, 07:11 PM
  3. Closed Loop Stepper Compared with Open Loop Stepper
    By Leadshine-Erci in forum Stepper & Servo Motors
    Last Post: 25-05-2012, 08:11 AM
