    Hi thanks for have a look at my post. i need to get hold of a moons sr4h step motor driver as one off mine is broken can any one please help me out on this.many thanks tom
    Does it have to be exactly the same? Can't you ge one that's the same spec but a different make? The BOB will not care what make it is as long as the parameters are the same for voltage and amps etc. etc?
    Neil...
    Build log...here
    Moons SR4 is just analog 24-48V stepper drive capable of running motors between 1 to 4.5A so any make will work just the same and probably cost less.
    Personaly if replacing I'd take the opportunity to upgrade to newer digital drive for better performance.
  1. Replies: 1
    Last Post: 16-03-2014, 06:29 PM
  2. Romi EZ-Path S Lathe crt replacement
    By Nemo1966 in forum Monitors
    Last Post: 07-10-2013, 03:25 PM
  3. New SCR driver board, or new motor & VFD?
    By m_c in forum Motor Drivers & Controllers
    Last Post: 04-11-2010, 04:16 PM
  4. Motor & Driver setup
    By action-kat in forum General Electronics
    Last Post: 19-07-2010, 10:24 AM
  5. Stepper Motor Driver v2.3 2A $20 !!!
    By Lee Roberts in forum Motor Drivers & Controllers
    Last Post: 17-05-2009, 09:57 PM
