    Can anybody shed some light on what wire gauge / mm / mm2 wire should be used for control panel wiring, 240v AC, 24v DC and signal wires?
    Some articles mention 14 AWG for mains AC and 16/18 AWG for DC / signal, but then it gets confusing with mm and mm2.
    Thanks again
    Quote Originally Posted by Dwayne Dibbley View Post
    Thanks again
    0.5 mm or 0.75mm is more than enough as there is hardly any current drawn. for the DC low voltage side ..Clive
  3. The Following User Says Thank You to Clive S For This Useful Post:
    Thanks Clive, so I'm assuming 0.5 and 0.75 are mm2. Would that equate to the top two items on this page http://www.csecables.com/acatalog/Tri-Rated-Cable.html?
  5. #4
    Yes they are fine but for the signal cables to the limits etc I would go with screened ie 3 or 4 core CY 0.5mm type I have used cat5 inside the control box for the BOB to the drives. ..Clive
  6. #5
    OK, can someone just cast their eyes over the main wiring for my cabinet ( attached image ), a little bit of reverse engineering from other diagrams on here and adapted to fit my needs i think?
  7. #6
    24V seems low for the power supply to the drivers. What is the max that the drivers can take and which motors are you using? ..Clive
  1. What gauge wire for motors and drivers etc?
    By glynster in forum Gantry/Router Machines & Building
    Last Post: 01-03-2015, 01:40 PM
  2. Mach 3 control panel help
    By IanParkin in forum Artsoft Mach (3 & 4)
    Last Post: 05-09-2014, 04:05 PM
  3. VFD to motor cable wire size (Gauge)
    By artman12us in forum Spindles & Drive Motors
    Last Post: 24-04-2014, 07:11 PM
  4. RFQ: Aluminium Control Panel
    By m_c in forum Projects, Jobs & Requests
    Last Post: 27-04-2013, 08:46 PM
  5. 30 gauge solid core insulated wire
    By Wobblybootie in forum General Discussion
    Last Post: 23-06-2010, 10:17 PM
