  1. #31
    Done some research and will start to collect parts for my AMA25LV conversion.
    For X and Y will use 5mm pitch 16mm ballscrew driven direct from Stepers Nema 24 4Nm
    https://tinyurl.com/yyg2v3rk - hard to find get those Nema 24 with 4Nm
    For Z will be 20mm ballscrew (double nut) 5mm pitch and Nema 34 - not sure what torque yet 8-10Nm (will use counter weight, 2spindle R8 and 2.2kw wet)
    https://tinyurl.com/create.php 8.5Nm
    Wonder if hybrid motor with close loop is not overkill?
    Here is open loop version:
    https://tinyurl.com/y53kcevf - Nema 24 X-Y
    https://tinyurl.com/y5rcpmx9
    https://tinyurl.com/y5zt582y - Nema 34 Z
    Any advice kindly appreciated
  2. #32
    Quote Originally Posted by Tom J View Post
    The motors look fine. I have almost identical on mine. However.
    I had to run my nema24's on 60vdc and my nema34 is a bit junk on 60v and is crying out for at least 80vdc.
    Bear that in mind when looking at drivers and power.
    Personally. I would get drivers that can run on ac power and use toroidal supplies.
    That's the route I'm going next (that's if I decide to change to a closed loop system).
    Daz.
  1. AMA25LV CNC Project !!!
    By Onocyclone in forum Milling Machines, Builds & Conversions
    Last Post: 27-09-2014, 08:21 PM
  2. AMA25lv clones
    By Onocyclone in forum Machine Discussion
    Last Post: 06-09-2014, 05:20 PM
  3. NEW MEMBER: complete beginner saying hi
    By helder1977 in forum New Member Introductions
    Last Post: 06-04-2013, 11:41 PM
  4. NEW MEMBER: complete newbie here :)
    By chudds in forum New Member Introductions
    Last Post: 18-05-2012, 08:37 PM
  5. Complete conversion kits?
    By leitzscope in forum General Discussion
    Last Post: 01-05-2010, 07:57 PM
