    Afnoon all.... I have a challenge from a customer where I will need to machine some Balsa wood which is 3mm thick.
    Small heart shapes, not many around 20 but are there any "Gotchas" I need to be aware of /
    Currently using LH 2mm 2 flute cutters at 18000rpm and around 1200mm min... Toofast or what ?
    Rob
    If you can't fix it with a hammer you've got an electrical problem !
    Long time since I did balsa ( prefer liteply) but biggest problem was furry edges / slightly ripped edges which needed cleaning up
    You could always lasercut it :)
    Quote Originally Posted by Trispectiv View Post
    If I had a laser would I be asking about feds and revs ?... But.as it happens the end result will be burned around the edges for artistic effect within a larger sculpture by a local artist.. So who knows....
  1. EXPERIENCE: machining service
    By D-man in forum Trading Experience & Feedback
    Last Post: 25-10-2014, 07:21 PM
  2. Plastics for machining?
    By Washout in forum Machine Discussion
    Last Post: 22-04-2014, 10:27 AM
  3. RFQ: RFQ: Need some thin aluminium cutting
    By stewpid22 in forum Projects, Jobs & Requests
    Last Post: 21-09-2012, 12:11 PM
  4. Replies: 5
    Last Post: 15-04-2012, 11:36 AM
  5. Looking for thin plastic? sheet
    Last Post: 08-09-2010, 11:32 PM
