    Hi All,
    I have been reading this forum with interest and busily designing my CNC machine.
    It will comprise of a steel frame, steel gantry and aluminium Z axis.
    I want it to be as accurate as possible and will be cutting acrylic, plastic, wood and hopefully light aluminium.
    Over all the machine size will be 2600mm x 1500mm (8' x 5') with a cutting area of 2200mm x 1150mm (7.5' x 4').
    I have already purchased 2500mm linear rails for the X axis and will mate them to dual HGH20 linear blocks on each side.
    The Y axis will use linear rails with HGH20 blocks also.
    I have read with interest the threads that use bolted top rails for the X axis and I am thinking of using epoxy to level the top of the rail between the linear rail and the top rail.
    I will have a rack and pinion system on either side of the X axis mated to NEMA34 stepper motors. I am going to use the R&P drive systems from CNCRouterParts.com
    Here is the frame design as it stands at the moment:
    The Gantry will be made from a 250mm x 150mm RHS steel beam and I am going to add a flat plate inside the bean to strengthen it.
    I am working out whether to use a ballscrew on the gantry or to use a R&P system here as well.
    Here it is:
    I would like to hear peoples opinions on the frame as this is what I will weld up first.
Name:	Steel Gantry 2 - Version 1.png
ID:	15371   Click image for larger version.
Name:	Steel Frame - Version 1.png
ID:	15369   Click image for larger version.
Name:	Steel Gantry 1 - Version 1.png
  1. Requesting some feedback on steel frame design.
    By Misc in forum Gantry/Router Machines & Building
    Last Post: 15-12-2014, 02:49 PM
  2. expanding foam and steel frame
    By Gytis in forum Metalwork Discussion
    Last Post: 18-08-2013, 10:35 AM
  3. BUILD LOG: 7' X 4' Steel frame build
  4. Steel frame for 8' * 4' cnc bed ?
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 18-10-2011, 08:57 PM
  5. Ideas sought to deburr a 5mm length of 5mm dia steel!
    Last Post: 22-03-2010, 08:48 PM
