    CNC gurus,
    Does anyone know what software creates GD4 files ? I have been given one and asked If I can do anything with it. Google searches turned up noting useful.
    Its for a gasket and I'm pretty sure its the file thats sent to a digital drag knife to cut.
    Its a bit of a long shot but Id like to try to convert it to something usable (DXF,EPS, or any vector file really).
    I know that its possible to convert g-code to dxf, I'm just not sure If this is.
    Any suggestions welcome.
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Has been a member for 9-10 years. Has a total post count of 2,553. Received thanks 167 times, giving thanks to others 656 times. Made a monetary donation to the upkeep of the community. Referred 10 members to the community.
    Only thing i can find out is:
    the gd3 file may have come from an old program called Gendesigner, which unfortunately is no longer available for download.
    If you want to send it to me or upload it to a post, I can look at the hex code for you, the name of the program that made the file maybe given here...
    .Me
    .Me
    Hi Lee, thanks for the reply. The Genedesigner I found seemed to be for doing family trees. File attached. If you can get any useful info out of it that would be appreciated !
    Attached Files Attached Files
    Hiya,
    I've had a look and pulled what I can, it looks as though it's from a Visual Basic project, and so is likely to be one file from a set of files that make up that project, I'm not sure it actually holds the gcode your looking for but rather points to each of the files that dose. If you can get all of the files from the project folder you could import the project into the latest Visual Studio and see how far you get, my experience with this is you end up having to track down the components needed for VB/VS to successfully do the import. The code below is the only thing i could find that resembles what may be coordinates, not sure if there is anything you can do with it.
    Towards the bottom of the code below is says "Husaberg 501 Water Pump", goggling this gives lots of results but I came to the conclusion that the same pump is used on many models of bike, this then took me on my travels towards gaskets and sets and I think that is what this "Project" was/is, a set of drawings for the individual gaskets, attached is also what looks to be a scan of the gaskets for the pump.
    You could import this scan into your favourite CAD programme and start building/drawing models for each gasket, the problem is your missing the dimensions, so you could either work out those demission's by measuring the related pump hardware OR just buy a set of gaskets and take the dimensions from those...
    Code:
    Title>Author>Company>
     blank.gd4.mdb
      Trevor Meyer
    P R O J E C T w m                                          LVAL   L  PU 531.437855,3161.231506;
    CI 180;
    PU 1880.676829,3611.353944;
    CI 139;
    PU 1737.943826,4797.801670;
    CI 172;
    PU 3013.516687,4133.128101;
    CI 105;
    PU 4370.975827,5366.026589;
    CI 106;
    PU 4735.323447,6769.032512;
    CI 141;
    PU 4486.975807,7687.957682;
    CI 131;
    PU 7271.533895,7542.902964;
    CI 133;
    PU 7895.679072,8366.941829;
    CI 172;
    PU 8932.853027,8988.671066;
    CI 136;
    PU 8107.247460,10274.611708;
    CI 136;
    PU 7089.671343,12860.402449;
    CI 134;
    PU 5179.826778,15110.316064;
    CI 132;
    PU 3138.453512,16401.796848;
    CI 131;
    PU 506.323947,14554.556947;
    CI 132;
    PU 685.158430,13695.721673;
    CI 170;
    PU 1041.192810,12193.980995;
    CI 131;
    PU 2470.504110,9599.420785;
    CI 134;
    PU 2151.881307,6119.933445;
    CI 182;
    PU 5585.972527,4001.958133;
    CI 105;
    PU 6979.532208,5031.801429;
    CI 141;
    PU 8184.392329,3500.223872;
    CI 111;
    PU 8205.228416,1908.919754;
    CI 112;
    PU 8870.128705,594.249499;
    CI 139;
    PU 9774.783990,1915.426489;
    CI 113;
    PU 11001.355594,797.700363;
    CI 141;
    PU 13445.437697,553.163508;
    CI 181;
    PU 13654.806208,2128.598519;
    CI 171;
    PU 14023.268241,3065.087575;
    CI 180;
    PU 11799.262877,4353.983831;
    CI 139;
    PU 12116.587603,4954.412882;
    CI 133;
    PU 11500.449859,6730.029645;
    CI 133;
    PU 12490.596559,6706.489373;
    CI 129;
    PU 13094.505880,8339.831179;
    CI 131;
    PU 12522.349185,9977.230716;
    CI 135;
    PU 11525.115987,9987.770356;
    CI 132;
    PU 11483.940858,13067.735313;
    CI 133;
    PU 12474.087558,13044.195041;
    CI 129;
    PU 13077.996879,14677.536846;
    CI 131;
    PU 14545.624704,14150.615919;
    CI 135;
    PU 15415.505380,8928.177140;
    CI 133;
    PU 9493.385890,5180.640166;
    CI 139;
    PU 9770.403616,3513.181389;
    CI 111;
    PU 6368.294650,2349.820007;
    CI 141;
    PU 6764.266033,786.185773;
    CI 140;
    PU 5199.454652,602.064242;
    CI 143;
    PU 4265.079968,2778.377265;
    CI 104;
    PU 9924.613907,14174.903209;
    CI 134;
    PU 11508.606985,16325.476992;
    CI 132;
    PU 12505.840184,16314.937353;
    CI 135;
    PU 4305.720751,4070.522953;
    CI 1045;
    PU3085.659637,4681.279940;
    PD2840.798808,4333.189892;
    AR264.229585,  LVAL   M  -202.281277,74.532804;
    PD 2839.6065822077,3930.19426332141;
    AR3392.790908,1646.294669,14.236226;
    PD 3348.65624425736,3146.39578404859;
    AR2834.036929,2986.864809,13.851276;
    PD 4146.13164537899,2554.77713703107;
    PD4274.769402,2537.464198;
    AR-896.902974,2506.278045,14.447323;
    PD 4871.69782047462,2840.48729758937;
    AR-985.933590,1704.379506,27.513369;
    PD 5547.53936178748,3488.7049044451;
    PD5802.610173,3853.697826;
    AR-289.451339,163.256593,66.981557;
    PD 5776.60018674622,4219.52155964749;
    AR-2857.475504,-1315.487352,19.426727;
    PD 5176.38475900702,5095.02717378493;
    AR-3813.973359,-4462.869968,8.476397;
    PD 4476.8876271198,5608.46497012367;
    AR-92.305048,-323.676727,54.362223;
    PD 4175.30743655496,5548.3992449413;
    AR2463.444823,-4815.522335,9.486505;
    PD 3415.3246489943,5076.53092397059;
    AR1963.612586,-1972.887141,10.609375;
    PD 3085.65958718968,4681.27989090977;
    PU8198.643805,2694.900667;
    PD8221.887595,2539.050279;
    AR765.305902,154.432242,162.128859;
    PD 9762.96444148395,2605.6082773352;
    AR-778.196730,114.084609,190.146577;
    PD 8198.6438052596,2694.90066759251;
    PU9776.550286,3763.767903;
    PU 9776.550286,3763.767903;PD;
    AR-1219.389051,-7617.697340,6.197086;
    PD 8947.10348967989,3850.88512660612;
    PD8123.859648,3744.951236;
    AR72.602718,-257.151610,78.520332;
    PD 7930.00556708958,3467.82765812024;
    AR9622.461993,-1283.974186,4.7769;
    PD 7856.50471058967,2662.04688316682;
    PD7969.252595,1852.328295;
    AR239.935634,43.255045,80.556648;
    PD 8212.4902815961,1651.80228284095;
    PD8980.988698,1568.251684;
    PD9827.929817,1670.729282;
    AR-49.430362,238.358976,75.450797;
    PD 10021.6322654792,1897.05502918562;
    PD10111.825728,2621.509780;
    AR-7064.592268,-280.723972,6.762632;
    PD 10029.6169375226,3451.45715198975;
    AR-304.513199,32.043677,58.413164;
    PD 9911.9010889692,3726.11541090986;
    PD9813.791701,3760.271403;
    PD9776.550286,3763.767903;
    PU4498.851552,712.885660;
    PD4569.440879,703.118715;
    AR-5.166258,234.543606,60.179372;
    PD 4770.33059054177,825.509163427843;
    PD5229.169207,1806.392622;
      LVAL   N
    AR482.173825,-170.959792,-25.671219;
    PD 5350.82317321159,1998.39877801028;
    AR-1030.606903,2233.382874,68.755439;
    PD 6775.26347593819,4383.08554287212;
    AR-2331.203704,-198.422133,88.27324;
    PD 4315.97410374831,6520.78757486307;
    AR101.470581,-2309.749005,91.309298;
    PD 2110.6172816192,4056.81770456041;
    PD2157.332068,3739.318565;
    AR-485.640256,-215.676881,-39.161423;
    PD 2184.44417195518,3384.18562423196;
    PD1680.014445,2307.590478;
    AR231.817369,-117.380772,79.43752;
    PD 1753.94609447437,1983.83713569262;
    PD1662.570944,1802.571421;
    AR130.086196,-62.978430,91.907239;
    PD 1734.04305647811,1607.48284662076;
    AR-50891.585372,-110952.647799,-1.277477;
    PD 4195.00919950409,445.311693447224;
    AR74.521740,110.675175,95.794061;
    PD 4387.16390093904,493.018855727562;
    PD4498.851552,712.885660;
    PU10776.231882,977.573351;
    PU 10776.231882,977.573351;PD;
    AR226.144779,-192.044529,-128.72511;
    PD 11293.674109721,841.816996214762;
    AR235.201459,239.939161,38.696943;
    PD 11495.3195594067,747.444144733807;
    PD12963.536473,487.601868;
    AR16.619188,122.205485,100.436032;
    PD 13103.3499533006,615.599098713821;
    AR368.205472,-67.141466,-98.500402;
    PD 13592.3861190293,902.693697211357;
    AR3.012202,150.071149,89.284703;
    PD 13745.4201708685,1047.87939602135;
    PD13857.022337,1588.569896;
    AR-162.848577,16.151807,97.960534;
    PD 13687.6168675732,1768.23790116395;
    AR12.205542,442.976854,-54.616466;
    PD 13331.5983515081,1964.6614929081;
    AR317.607799,158.580837,-122.747102;
    PD 13687.6333416831,2476.15300879432;
    PD13962.798538,2433.992757;
    AR-23.515361,137.482860,83.166823;
    PD 14078.5872983351,2578.46638060508;
    AR-123.840641,15.951931,105.489419;
    PD 13937.04627784,2718.02116447162;
    AR75.513567,345.624468,-111.89367;
    PD 13720.0205905967,3262.59124268962;
    AR-113.156504,52.122435,93.267664;
    PD 13652.4517920023,3430.65721478206;
    PD12174.591469,4195.000764;
    AR-68.158780,-125.421700,88.719703;
    PD 11982.5652086059,4140.52319288175;
    AR-191.229270,214.596320,-133.692407;
    PD 11504.0715872559,4365.08978778722;
      LVAL   O
    AR-154.379220,-54.338498,67.093557;
    PD 11359.7275574911,4474.10645808598;
    PD9087.644655,4969.232130;
    PD7315.840493,4986.170352;
    AR59.941620,-188.811793,55.476358;
    PD 7186.24982310508,4854.98148908244;
    PD7009.449747,4712.728332;
    PD6993.944036,4637.914623;
    AR-2553.072958,-405.349121,-29.666469;
    PD 6859.91824937216,3321.13792866095;
    AR-3106.901891,1096.718121,-12.985983;
    PD 6534.01298288912,2651.02618477792;
    AR349.612271,48.765171,33.458552;
    PD 6618.83490091966,2466.3543174838;
    AR-267.307251,-110.697513,-151.000636;
    PD 6171.4001667372,2129.24744982237;
    AR-87.294403,-132.779804,83.539731;
    PD 5961.99095705191,2098.1473537906;
    AR-1394.928412,1714.177427,-13.78037;
    PD 5513.52095680771,1815.21536951992;
    PD5457.643359,1726.081282;
    PD5259.711199,1271.806524;
    AR179.753583,5.561253,81.638817;
    PD 5418.82845691615,1098.71610411866;
    AR2514.905716,6882.885218,7.988139;
    PD 6399.73241878469,816.010048323761;
    AR-73.647407,200.725062,54.687899;
    PD 6532.45018818098,960.807433749045;
    AR222.719388,-173.145574,-143.536768;
    PD 7037.1906553185,780.775188859793;
    AR189.448500,46.221638,78.187721;
    PD 7233.10077067072,632.09833704469;
    AR1245.612564,8484.669204,8.504918;
    PD 8501.63279576663,541.18377898818;
    AR-75.539359,167.996371,64.751078;
    PD 8610.2614110704,705.843576485531;
    AR260.099903,-96.307498,-155.156036;
    PD 9146.8538168798,631.421909485013;
    AR160.787049,85.420569,80.482587;
    PD 9365.29994260013,544.14453482804;
    PD10584.702664,719.875814;
    AR-11.831129,157.394474,86.138826;
    PD 10730.705444335,878.475743587205;
    PD10776.231882,977.573351;
    PU13342.136054,173.059521;
    PD11068.415721,576.700389;
    AR-2399.527434,9401.984557,-16.91675;
    PD 8228.77739315279,285.3187650646;
    AR365.768244,9264.485856,-15.35487;
    PD 5788.62894678599,712.875510125985;
    AR-114.697672,-176.169986,109.83168;
    PD 5469.29722982906,584.833763960887;
    AR-281.936010,11.764904,-116.648116;
    PD 5050.39493831445,349.887167889821;
    AR-120.762841,-94.581349,97.643543;
    PD 4819.82850504633,362.415419849928;
    AR-424.493  LVAL   P  541,172.521353,-51.202576;
    PD 4526.85206032079,96.0043897584175;
    AR-78.782843,723.141479,-38.707885;
    PD 4057.33040191648,205.579642917974;
    PD1476.564307,1433.203472;
    AR162.036712,373.854286,-82.652664;
    PD 1247.09449399588,1919.95401159392;
    AR-143.219972,83.423162,85.250075;
    PD 1198.87077913611,2139.19725916587;
    PD291.332574,2836.538092;
    AR247.727568,333.113675,-79.477963;
    PD 166.30941356599,3352.38261516504;
    PD1069.754744,4995.484823;
    PD1250.825951,4914.267688;
    PD1385.182131,5150.549679;
    PD1203.722639,5252.082120;
    PD1776.711009,6285.955050;
    AR361.632832,-165.267713,-73.739797;
    PD 2195.74366425075,6514.12981364859;
    PD2838.594087,6373.997081;
    AR160.873277,528.931483,17.843625;
    PD 3008.40795075092,6350.14579394485;
    AR1355.476332,-2032.204460,-30.088277;
    PD 4209.86555185084,6755.86038203305;
    AR42.043295,284.894846,49.770832;
    PD 4442.26324537588,6824.65822444722;
    AR285.079917,-80.907280,-147.485413;
    PD 5011.22694178498,6828.76004037665;
    AR136.951788,-21.729239,95.473727;
    PD 5139.61231064984,6668.63076993535;
    AR-780.317842,-2618.639412,-42.942586;
    PD 6714.50358284725,5435.3282606302;
    AR1153.343232,442.050314,8.797411;
    PD 6795.68002499783,5264.13517633724;
    PD7415.561584,5262.435731;
    AR-30.980410,-26505.358872,-2.682127;
    PD 8655.84199178531,5231.94993995124;
    PD9130.063845,5230.853631;
    AR-105.670387,273.798138,42.181633;
    PD 9286.54813309489,5372.71778025226;
    AR201.343773,-201.492191,-139.599182;
    PD 9771.81432872148,5148.28052636622;
    AR154.509395,70.247684,60.905921;
    PD 9912.57829541613,5049.35683689482;
    PD11820.878924,4625.181890;
    AR-760.313705,-2411.694529,-12.005252;
    PD 12305.8854735861,4414.28832763394;
    PD14211.645643,3414.249462;
    AR-173.046688,-353.878020,-80.099454;
    PD 14416.9602988797,2950.74707096685;
    PD14239.517844,2141.239692;
    PD14045.464655,2184.923774;
    PD13969.105075,1929.120608;
    PD14176.503823,1885.971961;
    PD13841.912420,429.875076;
    AR-377.473112,132.960110,-54.948863;
    PD 13572.3784376231,177.46071171508;
    AR-129.574140,753.886065,-17.3146  LVAL   Q  42;
    PD 13342.1360489744,173.059522242301;
    PU12208.254755,9539.632215;
    PD12022.024424,9544.353640;
    PD11563.093762,9546.197447;
    AR-6.637003,-151.443375,63.479971;
    PD 11423.9120014199,9468.31379520675;
    AR2695.050949,-467.935474,14.446464;
    PD 11392.3880332033,8781.16963832883;
    AR135.646197,10.499398,94.567182;
    PD 11549.3015202627,8657.28960892223;
    PD12447.242386,8640.311666;
    AR15.342197,138.652691,79.119337;
    PD 12595.8485869532,8737.72533445215;
    AR-3362.498099,427.775795,10.230144;
    PD 12618.3666750022,9341.71409559833;
    AR-158.556266,23.686375,104.048512;
    PD 12444.2998582485,9524.96411561753;
    PD12208.254755,9539.632215;
    PU11805.722500,8066.673530;
    PD12121.998881,8049.109402;
    PD12420.207310,8037.915759;
    AR16.240560,-171.913482,-56.369181;
    PD 12570.5924038105,7974.7370236601;
    AR-3641.659849,-416.215938,-9.681052;
    PD 12588.7243036446,7356.41587143642;
    AR-160.711122,-31.554666,-81.668903;
    PD 12482.5208164482,7170.4180783124;
    PD11735.876800,7177.216331;
    AR-33.550877,1030.159821,-16.721601;
    PD 11438.0588317485,7211.12426485915;
    PD11389.025970,7266.499033;
    AR2313.297777,313.936292,-14.839094;
    PD 11385.7762958851,7869.4171708675;
    AR191.654127,14.324140,-64.782788;
    PD 11482.8169368872,8051.02781277551;
    AR191.505563,-971.155967,-19.661242;
    PD 11820.7355296881,8058.84146618459;
    PD11805.722500,8066.673530;
    PU11620.704257,6382.452628;
    PD11482.956460,6387.853733;
    AR8.417899,328.792417,-83.132741;
    PD 11163.9342303491,6685.69010617451;
    PD11154.704537,7293.255067;
    PD11186.525954,9932.878581;
    AR377.502832,27.033927,-83.561009;
    PD 11494.8302680118,10332.0022639532;
    PD12529.055876,10312.677653;
    AR-0.986385,-332.301876,-86.793754;
    PD 12859.9063747459,9997.97669556388;
    PD12842.957496,9013.694716;
    AR324.021094,-26.461150,64.942387;
    PD 13005.7754497512,8704.91564345487;
    AR-131.150503,-753.188404,-27.998705;
    PD 13344.0108656122,8555.19230541708;
    AR-235.100969,-223.726399,-125.527151;
    PD 13154.372933829,8010.12639781467;
    AR-30.362069,-295.009009,90.758876;
    PD 12828.62560  LVAL   R  17292,7741.56954860582;
    PD12819.797031,6701.103286;
    AR-327.840304,-2.747595,-92.15383;
    PD 12482.3812990153,6370.64373610057;
    PD11620.704257,6382.452628;
    PU12191.745754,15877.337883;
    PD12427.790850,15862.670751;
    AR15.510180,-159.564128,-104.048512;
    PD 12601.8576749295,15679.4197705979;
    AR-3385.016188,-176.212974,-10.230144;
    PD 12579.3395881088,15075.4310091757;
    AR-133.263420,41.239500,-79.119337;
    PD 12430.733392095,14978.0183012556;
    PD11532.792541,14994.995279;
    AR-21.267312,134.379424,-94.567182;
    PD 11375.8790335404,15118.8752834155;
    AR2726.574915,219.208705,-14.446464;
    PD 11407.4029962479,15806.0194406527;
    AR132.544762,-73.559701,-63.479971;
    PD 11546.5847389563,15883.9031086624;
    PD12005.515423,15882.059308;
    PD12191.745754,15877.337883;
    PU11789.213499,14404.380166;
    PD12105.489880,14386.816038;
    PD12403.698308,14375.622395;
    AR16.239657,-171.913966,-56.369181;
    PD 12554.0834019173,14312.4426918594;
    AR-3641.656988,-416.215696,-9.681052;
    PD 12572.215301831,13694.1220241767;
    AR-160.711121,-31.554667,-81.668903;
    PD 12466.0118160628,13508.1242312247;
    PD11719.367799,13514.921999;
    AR-33.549229,1030.160063,-16.721601;
    PD 11421.5498308071,13548.8304172575;
    PD11372.516968,13604.204700;
    AR2313.297778,313.936292,-14.839094;
    PD 11369.2672939185,14207.1228381236;
    AR191.654128,14.324140,-64.782788;
    PD 11466.3079357071,14388.7334807592;
    AR191.506961,-971.155726,-19.661242;
    PD 11804.2265289322,14396.5476186492;
    PD11789.213499,14404.380166;
    PU11604.195255,12720.158780;
    PD12465.872298,12708.349888;
    AR9.575194,327.712197,92.15383;
    PD 12803.2880291358,13038.8099229182;
    PD12812.116600,14079.276183;
    AR295.385024,-26.452400,-90.758876;
    PD 13137.8639300331,14347.8325493809;
    AR-45.463159,321.339752,125.527151;
    PD 13327.5018667169,14892.8989413283;
    AR-469.385921,-603.465066,27.998705;
    PD 12989.2664506513,15042.6222803645;
    AR161.203138,282.317923,-64.942387;
    PD 12826.4484957229,15351.4013512405;
    PD12843.397374,16335.683332;
    AR-331.836884,-17.600918,86.793754;
    PD 12512.54687  LVAL   S  55772,16650.3842902222;
    PD11478.321267,16669.707931;
    AR69.197975,-372.089271,83.561009;
    PD 11170.0169527875,16270.5852181778;
    PD11138.195536,13630.961703;
    PD11147.425229,13023.396742;
    AR327.440675,30.955560,83.132741;
    PD 11466.4474593189,12725.5594004213;
    PD11604.195255,12720.158780;
    PU11408.345735,11467.657609;
    PD11404.776326,11525.515171;
    PD11323.248660,11584.313531;
    AR837.753956,1668.033605,-35.556693;
    PD 10509.4805660149,12382.4950125813;
    AR5605.468967,2701.174033,-13.628646;
    PD 10030.8396635408,13779.3567386909;
    AR-109.404183,14.298582,95.162517;
    PD 9925.83175740245,13903.9023044838;
    AR-84.177578,-355.213240,41.451118;
    PD 9669.60266459763,13870.6527068427;
    PD9564.780853,13632.270680;
    AR10504.999510,-3887.291007,9.446591;
    PD 9069.22499381963,11855.3890285044;
    AR14771.913839,-2382.220148,9.440543;
    PD 8878.54937201703,9400.17624147064;
    AR68.254937,-19.189782,171.647373;
    PD 9011.54764634526,9352.08517108376;
    AR3164.056195,-1189.608109,-53.247755;
    PD 11235.521990477,11409.4241158412;
    AR-7.291104,307.205834,34.523642;
    PD 11408.3457256053,11467.6576035443;
    PU12985.918916,11474.979548;
    PD13009.400085,11531.334354;
    AR-731.309391,1643.565193,37.10469;
    PD 13852.8541529487,12305.2789300837;
    AR-9239.641553,4400.901317,8.365265;
    PD 14394.808443925,13696.3146064238;
    AR246.877118,-14.390489,-46.606036;
    PD 14482.5350818755,13871.2030706399;
    PD14658.739315,13868.197572;
    AR31.823446,-134.724994,-56.717926;
    PD 14785.7265637446,13834.0081755304;
    AR-10542.219571,-3860.144010,-5.86482;
    PD 15124.9822183088,12736.5806141893;
    AR-13104.233096,-3041.612767,-14.596917;
    PD 15468.5523793846,9335.91239362199;
    AR-62.462246,-22.382891,-167.393716;
    PD 15350.0187465906,9278.0537980439;
    AR-3172.508138,-1097.492605,54.654868;
    PD 13117.6024405298,11403.219296103;
    AR-2.425765,152.251578,-59.001452;
    PD 12985.9189231717,11474.9795040313;
    PU15305.870071,8239.238566;
    PD15284.644490,8650.820300;
    PD15182.454169,8826.084678;
    AR386.673638,134.275151,-37.229118;
    PD 15180.0125534388,908  LVAL   T  7.38595995823;
    PD15149.580532,9211.179731;
    AR-2931.548281,-1000.864689,74.313856;
    PD 12047.0383610728,11303.2855460832;
    AR45.926757,-3041.872010,66.372276;
    PD 9287.68947961352,9438.4960247852;
    PD9168.965946,9133.050948;
    AR-407.180384,-131.238141,-32.290979;
    PD 9176.10379486127,8895.23083532451;
    PD9072.033819,8731.425579;
    AR2792.674000,-610.213904,44.036396;
    PD 9432.89003834217,6618.66338606305;
    AR2699.387389,1707.586373,48.301289;
    PD 11611.5830808724,5174.83406236528;
    AR307.257909,1562.214416,10.629091;
    PD 11905.0061342002,5144.96496891407;
    AR226.642191,-382.152121,-37.311097;
    PD 12183.0257013153,5204.13732202405;
    AR336.658529,669.823926,15.118135;
    PD 12369.3742430893,5139.51590314382;
    AR-129.237189,3100.749702,63.321177;
    PD 15068.798925303,6963.54207093269;
    AR-2695.367909,1165.023154,25.201773;
    PD 15308.3126555391,8222.14341642126;
    PD15305.870071,8239.238566;
    PU14940.149043,16857.658050;
    PU 14940.149043,16857.658050;PD;
    AR13.648369,-114.125301,-123.577453;
    PD 15056.4280629919,16691.7851714559;
    PD14815.788468,15840.257304;
    PD14381.472583,14433.066239;
    AR412.688693,-438.793877,23.310375;
    PD 14241.5224864326,14233.9437872643;
    PD14253.169574,14016.225343;
    PD13724.928043,12566.768174;
    AR-1508.830799,639.014873,-103.248742;
    PD 11248.297842631,11883.5596518674;
    PD11072.656574,12018.813506;
    AR1452.759829,1549.749388,-31.849281;
    PD 10473.6033539155,13018.7470175748;
    PD10204.227303,14030.888600;
    AR-615.637801,147.665473,22.207667;
    PD 10214.3716337532,14274.5317657979;
    AR-2026.073043,-1104.375662,6.044253;
    PD 10086.8214605603,14481.7309172301;
    AR65738.124810,14786.509260,-1.999195;
    PD 9611.00101415335,16784.0356286305;
    AR133.312363,-1.753603,-94.85267;
    PD 9757.33809973232,16914.9681888343;
    PD11700.093572,16902.000497;
    PD14940.149043,16857.658050;
    PU15464.615759,12256.433057;
    PD15539.755501,11838.463398;
    AR-12894.135422,-1981.527315,-13.234137;
    PD 15650.9546072729,8833.97343036867;
    PD15506.682272,7763.410861;
    AR-3163.909088,386.849980,-59.832124;
    PD 13  LVAL   U  598.2954311205,5220.47629070618;
    PD12355.659527,4770.576206;
    AR-273.759092,607.361633,-29.580468;
    PD 12020.157366207,4714.5978152195;
    PD11004.448307,5113.596026;
    AR1070.532652,3106.746029,-62.060334;
    PD 8828.7636698657,7710.4554407111;
    PD8683.746258,9007.379458;
    AR15518.299923,489.670034,-7.180308;
    PD 8744.24017662159,10950.8867502178;
    AR9464.832201,-618.523109,-11.629396;
    PD 9063.21684683724,12846.1150288635;
    AR7598.216716,-2061.890985,-14.473592;
    PD 9819.69806162226,14679.7274810956;
    PD9642.932889,15527.311983;
    PD9419.017388,16686.165581;
    AR301.485373,113.509625,-107.759956;
    PD 9704.36470495482,17121.416450244;
    PD11925.139773,17106.569103;
    AR-26.766145,-118721.388115,-1.460848;
    PD 14951.7957522604,17067.2998000184;
    AR20.599921,-313.621480,-98.093376;
    PD 15285.7936608846,16729.9193079562;
    AR-27081.679886,6528.342881,-3.426751;
    PD 14847.1574410408,15122.8537528215;
    PD14766.944535,14839.011911;
    AR1097.992936,-383.222176,10.880664;
    PD 14714.3451659785,14624.8609368925;
    AR-19278.357265,-7815.798100,-3.036656;
    PD 15101.3160400819,13592.6185385967;
    AR-12046.541116,-4052.412837,-4.424084;
    PD 15378.0178933794,12651.2964074128;
    PD15464.615759,12256.433057;
    PU5926.363735,7039.237453;
    PU 5926.363735,7039.237453;PD;
    AR-88.942949,1949.306790,-36.902668;
    PD 4738.0688026162,7376.36155287241;
    AR117.404107,91.313219,-84.454316;
    PD 4753.24122496863,7575.7049112838;
    AR-276.686950,100.716694,167.095176;
    PD 4229.3490541926,7836.38753725319;
    AR-72.227369,132.416812,-83.75574;
    PD 4033.34644550969,7882.60286999419;
    AR5975.948637,7323.227125,-11.587254;
    PD 2684.19313347222,9232.17959751544;
    AR137.404492,86.603704,-84.26838;
    PD 2721.7044539708,9446.85183952655;
    AR-255.718494,148.023374,153.51896;
    PD 2303.10081343265,9841.39356337167;
    AR-10.047943,169.715182,-76.314453;
    PD 2130.53337430341,9961.19263977445;
    AR8858.744494,6000.471111,-10.935385;
    PD 1153.0922653294,11750.6709522567;
    AR119.201768,79.281320,-105.280815;
    PD 1227.23128042225,11965.8343436877;
    AR-192.663679,2  LVAL   V  26.144056,154.639235;
    PD 957.332368880499,12478.8497065006;
    AR-3.107526,123.474896,-89.15119;
    PD 830.809530636614,12597.3882625647;
    AR2245.454040,919.094863,-14.992397;
    PD 669.48297444833,13209.5525549586;
    AR170.027837,-24.275469,-76.507269;
    PD 823.44503081703,13356.2760751862;
    AR-143.658111,338.987968,171.964711;
    PD 584.923972749552,14051.0048424102;
    PD518.842039,14075.480052;
    PD471.814300,14149.996795;
    AR120.737014,-1.403544,-96.833174;
    PD 608.310041942414,14268.305652108;
    AR-102.204016,278.494185,164.642069;
    PD 481.310376627494,14842.4175760916;
    AR33.012635,131.306976,-84.978967;
    PD 380.630595462266,14995.1183309263;
    AR5318.465360,341.010231,-7.103799;
    PD 379.284711387311,15655.4561220881;
    AR1495.871699,-265.796120,-104.379296;
    PD 2504.11050909632,16772.6626980907;
    PD2800.686072,16651.709738;
    AR-96.399870,-133.921109,-85.757807;
    PD 2844.97135345077,16431.5593617349;
    AR294.640716,-30.278560,160.773765;
    PD 3407.84870083539,16275.666106281;
    AR99.390876,-92.864163,-90.682087;
    PD 3601.28034698797,16281.0802858163;
    AR-4056.141771,-7491.100275,-10.232467;
    PD 4867.50495648828,15441.3923050586;
    AR-87.444415,-135.600614,-100.674802;
    PD 4897.11678029583,15194.7426514946;
    AR279.552563,-91.111807,153.909192;
    PD 5387.6644548439,14898.857653476;
    AR55.613598,-189.376465,-76.433903;
    PD 5614.32579734144,14807.9646238243;
    AR-6436.001853,-6634.919095,-12.943089;
    PD 6936.9163155704,13197.8356403268;
    AR-196.123449,-11.390031,-60.194691;
    PD 6848.16023446691,13021.9269526233;
    AR239.898922,-168.639583,152.110709;
    PD 7221.21092435429,12592.0185276858;
    AR21.385415,-151.142334,-88.004823;
    PD 7392.90250320506,12467.5107203428;
    AR-9321.141798,-4615.738091,-10.62103;
    PD 8083.94697225537,10670.4334280146;
    AR-134.702012,-3.434366,-83.302809;
    PD 7968.365115365,10533.6167294578;
    AR145.568959,-258.789089,165.644599;
    PD 8190.79475528965,9988.02709918428;
    AR-20.844640,-137.453594,-91.893905;
    PD 8306.63973183252,9825.19756692552;
    AR-2474.140656,-301.848972,-25.508116;
    PD 8195.459  LVAL   W  04486683,8730.31330434218;
    AR-107.683116,81.087158,-92.916245;
    PD 8001.31528407498,8707.98219737056;
    AR-110.196336,-338.908080,172.018944;
    PD 7734.93404882702,8048.74897484732;
    AR-112.950526,-102.364949,-100.778626;
    PD 7701.41902862564,7816.2825099323;
    AR-167.081037,108.704949,-62.046674;
    PD 7516.63527204261,7726.4441326004;
    PD7417.978493,7798.388938;
    AR-150.783995,-242.890637,148.841006;
    PD 7012.48820165016,7425.66618906241;
    AR-149.638340,-52.254866,-105.407249;
    PD 6873.47115364548,7215.26774303471;
    AR-58.062727,66.383639,-101.421186;
    PD 6738.84174611627,7237.88368699293;
    AR-109.391265,-45.358592,81.496847;
    PD 6600.76549515241,7307.42079700074;
    PD6012.201046,7207.468138;
    PD5967.523846,7176.809880;
    PD5926.363735,7039.237453;
    PU6624.694292,6903.283566;
    PU 6624.694292,6903.283566;PD;
    AR-292.802351,1565.125401,15.85322;
    PD 7041.10886582714,7042.79959162915;
    AR-1830.293606,3744.545166,7.292543;
    PD 7501.61933137169,7305.41858228778;
    AR-1710.598239,2168.139465,54.141477;
    PD 8550.26838224304,9589.87428090817;
    AR-5177.489203,-430.815063,14.234345;
    PD 8285.37733119893,10849.7322979118;
    AR-8965.476667,-2630.223325,29.426631;
    PD 5836.44980728093,14915.2116151581;
    AR-6664.614919,-6821.063640,23.201591;
    PD 2610.16814897125,16989.1952256833;
    AR-731.001253,-1588.750183,110.209957;
    PD 135.698658979627,15537.5890597221;
    AR8212.694386,-172.017642,14.1577;
    PD 343.075408730097,13523.6081475572;
    AR11088.624286,2543.280603,18.222812;
    PD 1694.51349993409,10183.6014222593;
    AR7797.887139,4839.741371,10.554812;
    PD 2712.9776153046,8837.10291444232;
    AR8795.257402,8146.410069,10.232156;
    PD 4299.96121107488,7404.29910575573;
    AR1679.075981,2044.976518,41.413441;
    PD 6072.53128306642,6804.94509155407;
    PD6161.352252,6803.400185;
    AR-14.236935,86.026960,58.920982;
    PD 6228.14302557513,6857.2116423949;
    PD6232.898362,7001.424390;
    AR43.692249,-15.227845,-50.033787;
    PD 6260.19649287979,7029.46469468406;
    PD6483.163930,7070.774500;
    AR-6.820384,-39.555521,-73.024448;
    PD 6516.16691417487RLVAL ^               @      @      @      @      @        o HZ  g
    o HZ   o HZ  o HZ  o HZ  o HZ  o HZ  o HZ      o HZ
    o HZ  8Ř  M 8Ř  M8Ř  M8Ř  M8Ř  M8Ř  M8Ř  M8Ř  M8Ř  M8Ř  M    8Ř  M
    8Ř  M8Ř  M8Ř  M
    8Ř  g 8Ř  g8Ř  g8Ř  g8Ř  g8Ř  g8Ř  g8Ř  g8Ř  g8Ř  g    8Ř  g
    8Ř  g8  g8  6aG  6aG  6aG        ,7036.24453635194;
    PD6552.110495,6941.235666;
    AR58.578624,27.906021,76.688193;
    PD 6624.3576011952,6905.71161690493;
    PD6624.694292,6903.283566;
    PU0,0;SP0;)        7Ww       *  *
             w)
           (g                      $  
                        (           0
             Nf          4           <
             2 IDGasket #MakeModel    From YearTo YearGasketMaterial    ThicknessGasketsInSetCommentsMaxXMaxYhpglhpgldatetimeCutQtyOEMcreateddatewebdateInSet          *  +              *  ,              *  -                  *  .              *  /                  *  0
    *  1              *  2              *  3               H@     H@      .@   #        P!6c@   yKsKL@׍.6c@9HusqvarnaSet9Da @ g      AbaaUTSROFE           H@     H@      .@   0     !6c@   yKsKL@׍.6c@8HusqvarnaSet8Da~ @ f      AbaaUTSROFE           H@     H@      .@        !6c@   [KL@׍.6c@7HusqvarnaSet7Da   d      AbaaUTSROFE           H@     H@      >@
      l
      n!6c@   [KL@׍.6c@5HusqvarnaSet5Ba @Y      CbaaUTSROFE           H@     H@      .@     7  9x!6c@   BKL@׍.6c@3HusqvarnaSet3Da   `      AbaaUTSROFE           H@     H@      .@     *  9x!6c@   BKL@׍.6c@2HusqvarnaSet2DaG   ]      AbaaUTSROFE           H@     H@      .@   0  h  _!6c@   ŨKL@׍.6c@1HusqvarnaSet1Da   Z      AbaaUTSROFE           H@     H@      >@
      l
      G!6c@   4KL@׍.6c@5HusqvarnaSet SET CBa @ Y      fffZYXROFE           H@     H@      .@   #=  B  Lh/!6c@   IKL@׍.6c@00HusqvarnaSet SET ADa_   K      ggg[ZYSPGE     LVAL i     N              *  *
             w)
    PU 370.662090,335.993061;
    CI 145;
    PU 2372.230063,359.765232;
    CI 138;
    PU 2364.094010,2350.599726;
    CI 141;
    PU 361.049835,2340.506262;
    CI 141;
    PU 1395.104342,1354.929718;
    CI 1073;
    PU2678.814588,945.180649;
    PD2673.858933,1881.052397;
    PD2670.215646,2430.327185;
    AR-261.520728,-21.476301,94.84198;
    PD 2365.2208338458,2667.62554791679;
    PD920.648229,2661.300843;
    PD303.559484,2657.249167;
    AR13.911004,-269.490005,91.91917;
    PD 48.5975224221513,2364.83085616287;
    AR-25001.822628,-805.544950,-3.169356;
    PD 54.8932168392175,981.310681022177;
    PD52.940428,350.317870;
    AR262.137956,-45.378054,107.748698;
    PD 351.771032499963,41.4457452759265;
    AR801.777815,-9334.605174,-3.997946;
    PD 1004.53743710761,74.6309733929379;
    PD2040.143981,62.782830;
    PD2422.335739,39.906830;
    AR42.097905,197.243130,90.000001;
    PD 2661.67677473475,195.052058442541;
    PD2690.262324,949.615342;
    PD2678.814588,945.180649;
    PU0,0;SP0;PU 370.662090,335.993061;
    CI 145;
    CI 138;
    CI 141;
    CI 141;
    CI 1073;
    PU0,0;SP0;  LVAL   [  PU 3009.941707,1222.272254;
    CI 134;
    PU 2975.178483,5843.215592;
    CI 135;
    PU 8186.075300,6779.758663;
    CI 133;
    PU 12201.669176,3531.887844;
    CI 133;
    PU 8208.422862,296.862936;
    CI 136;
    PU5698.006336,2740.476032;
    PU 5698.006336,2740.476032;PD;
    AR-246.649348,-183.281441,-34.523642;
    PD 5758.44358084259,2568.41118496574;
    AR3234.669562,981.494712,53.247755;
    PD 7844.0325869474,370.907167556923;
    AR-28.071180,-65.107453,-171.647373;
    PD 7797.64582056753,237.305110718159;
    AR-264.180868,14960.436256,-9.440543;
    PD 5340.19682319921,396.592106896544;
    AR1969.671398,11026.626840,-9.446591;
    PD 3557.12756524181,869.40245926325;
    PD3317.425124,971.169379;
    AR319.738882,176.151249,-41.451118;
    PD 3280.90432423312,1226.95262115749;
    AR110.294478,-2.987007,-95.162517;
    PD 3404.09810538204,1333.54390569085;
    AR-1381.947906,6066.947065,13.628646;
    PD 4794.72983267831,1829.99468394179;
    AR-890.885014,1640.273134,35.556693;
    PD 5582.44819551073,2653.89610959965;
    PD5640.199156,2736.168083;
    PD5698.006336,2740.476032;
    PU263.315917,6203.116469;
    PD260.379438,2962.759187;
    PD272.238107,1019.996417;
    AR132.841341,-11.327910,94.85267;
    PD 405.029703022227,875.345062140952;
    AR-13329.273857,66048.998279,1.999195;
    PD 2701.06578487843,1380.54573580927;
    AR1335.729577,-1881.607233,-6.044253;
    PD 2906.61805751673,1510.73335889074;
    AR103.965508,-624.506019,-22.207667;
    PD 3150.37143376702,1503.70280235466;
    PD4158.988392,1785.989753;
    AR-575.991129,2044.620032,31.849281;
    PD 5151.18527614805,2397.77231642195;
    PD5284.183063,2575.126599;
    AR-1334.482049,950.825352,103.248742;
    PD 4569.38418772728,5042.82503511365;
    PD3113.295428,5552.501566;
    PD2895.742903,5538.074236;
    AR232.588828,555.655497,-23.310375;
    PD 2694.84858568581,5675.46790473301;
    PD1282.222508,6091.767185;
    PD427.689431,6321.505744;
    AR-50.431873,-103.283613,123.577453;
    PD 263.315917390743,6203.11646769471;
    PU8876.358700,6678.936423;
    PD8465.082168,6652.452648;
    PD8291.137425,6548.030963;
    AR-139.205121,384.925845,-37.229118;
    PD 8029.88894782244,65  LVAL   \  42.25053587923;
    PD7906.493393,6510.239699;
    AR1038.242978,-2918.519700,74.313856;
    PD 5854.20334721678,3381.21738723535;
    AR3041.037365,84.792462,66.372276;
    PD 7754.10029287973,645.92180792224;
    PD8061.037952,531.111762;
    AR136.429995,-405.469702,-32.290979;
    PD 8298.74712662905,541.287763152739;
    PD8463.869111,439.319410;
    AR574.478880,2800.242895,44.036396;
    PD 10571.8473848473,827.143215448213;
    AR-1741.939393,2677.347633,48.301289;
    PD 11987.7197299308,3024.10743688907;
    AR-1566.016269,287.267184,10.629091;
    PD 12013.8362933627,3317.88873918887;
    AR379.225254,231.505997,-37.311097;
    PD 11951.1168153952,3595.12955602353;
    AR-674.069070,328.071958,15.118135;
    PD 12013.3518461582,3782.28809415805;
    AR-3098.845585,-168.848936,63.321177;
    PD 10154.9802905922,6458.18485942986;
    AR-1130.485458,-2710.035450,25.201773;
    PD 8893.42090859611,6681.59604031192;
    PD8876.358700,6678.936423;
    PU5670.527021,4317.826609;
    PD5613.876702,4340.586921;
    AR-1634.084955,-752.251717,37.10469;
    PD 4829.21760102499,5174.08171728663;
    AR-4282.477705,-9295.123939,8.365265;
    PD 3431.3701088072,5698.21706147426;
    AR11.234426,247.041090,-46.606036;
    PD 3255.37468203111,5783.70167665373;
    PD3256.128469,5959.930132;
    AR134.307114,33.542388,-56.717926;
    PD 3288.69230226679,6087.34369496545;
    AR3994.546225,-10492.027827,-5.86482;
    PD 4381.69467821077,6440.59552123629;
    AR3208.811355,-13064.299802,-14.596917;
    PD 7777.69573187726,6827.591554345;
    AR23.178996,-62.171380,-167.393716;
    PD 7837.06386501372,6709.80639191801;
    AR1137.941434,-3158.225038,54.654868;
    PD 5740.59800503502,4450.41701977053;
    AR-152.208377,-4.372049,-59.001452;
    PD 5670.52706543015,4317.82661731187;
    PU4857.464283,6786.336007;
    PD4463.739283,6694.699375;
    AR3268.308867,-12282.483846,4.424084;
    PD 3526.02967904484,6405.99145234231;
    AR7034.270381,-19577.040745,3.036656;
    PD 2498.81633264475,6005.86297802952;
    AR154.351240,1152.657668,-10.880664;
    PD 2284.01086375588,6055.7208777055;
    PD1999.166869,6132.300421;
    AR-7794.304100,-26744.813818,3.426751;
    PD 386LVAL        X ,873.535408;
    CI 127;
    PU 4336.896884,1337.430143;
    CI 131;
    PU 3814.294322,1503.601684;
    CI 174;
    PU7393.662620,2942.965148;
    PU 7393.662620,2942.965148;PD;
    AR-1162.000719,-1043.639786,-35.307711;
    PD 7783.11382374137,2079.39925044795;
    PD7888.096016,1192.127509;
    AR-314.549853,217.915340,-30.214136;
    PD 7735.70240319313,1063.43924371572;
    AR198.266116,-220.266641,56.524414;
    PD 7640.87956008094,799.28971511565;
    AR-179.147782,53.394607,-66.222682;
    PD 7485.09869005628,667.214919429633;
    PD6763.767052,352.267256;
    AR-512.138458,1500.808961,-54.771398;
    PD 5321.10425666582,569.005426424453;
    AR2507.708911,2938.393688,-8.567696;
    PD 4911.33338241423,975.389408673605;
    PD4616.705028,1198.900569;
    PD4592.999560,1253.085051;
    AR-264.251556,59.551470,1    .628148263713,6550.36604091117;
    AR-19.752721,-313.676616,98.093376;
    PD 53.5421268603373,6212.0838892328;
    AR118711.442354,-1536.619749,1.460848;
    PD 52.951479440715,3185.17333258743;
    PD66.483596,964.389294;
    AR321.508445,20.247963,107.759956;
    PD 505.344695636434,684.627232731228;
    PD1661.242105,923.332310;
    PD2506.499042,1110.913886;
    AR3807.761258,6890.954155,14.473592;
    PD 4349.62821813292,377.924458631612;
    AR2396.677653,9177.232058,11.629396;
    PD 6248.7780972063,83.1916659672006;
    AR1256.192591,15475.117316,7.180308;
    PD 8192.89918403577,47.5375584219601;
    PD9487.864157,209.115463;
    AR-551.325380,3239.436208,62.060334;
    PD 12056.7099006154,2417.8049612356;
    PD12442.697299,3438.529728;
    AR-664.075589,53.261013,29.580468;
    PD 12382.4359089774,3773.28947372312;
    PD11916.693915,5010.075413;
    AR-2913.501137,-1292.857236,59.832124;
    PD 9349.58155353772,6885.8114806853;
    PD8277.262849,7016.392848;
    AR-856.690829,-13017.345662,13.234137;
    PD 5274.43889619516,6866.8100014777;
    PD4857.464283,6786.336007;
    PU0,0;SP0;  LVAL   ^  PU 1819.134802,1613.314141;
    CI 131;
    PU 4338.855021,419.239486;
    CI 133;
    PU 5229.684175,943.663541;
    CI 172;
    PU 6151.478727,2627.189927;
    CI 136;
    PU 6194.785425,5405.661175;
    CI 134;
    PU 5285.142269,8213.181105;
    CI 132;
    PU 3889.045294,10184.485099;
    CI 131;
    PU 751.913476,9478.223653;
    CI 132;
    PU 590.370467,8615.969149;
    CI 170;
    PU 347.966180,7091.756405;
    CI 131;
    PU 682.060994,4148.449237;
    CI 134;
    PU2903.230281,465.527837;
    PU 2903.230281,465.527837;PD;
    AR659.754477,1836.418607,-36.902668;
    PD 1932.71641441257,1229.5965020715;
    AR143.324568,39.749259,-84.454316;
    PD 2022.62697262895,1408.1581482801;
    AR-217.520122,198.455169,167.095176;
    PD 1637.40219328365,1848.63522734153;
    AR-16.385606,149.941862,-83.75574;
    PD 1473.74651241737,1965.97992496202;
    AR8313.654789,4497.192218,-11.587254;
    PD 739.873124003589,3727.51359775716;
    AR160.026417,27.781270,-84.26838;
    PD 856.275501381791,3911.74676565677;
    AR-180.122875,234.219293,153.51896;
    PD 619.366656089428,4435.92861042919;
    AR55.310446,160.763747,-76.314453;
    PD 505.391558144206,4612.39688754885;
    AR10475.924998,2176.679679,-10.935385;
    PD 282.695935593813,6639.2239452178;
    AR140.406904,27.939060,-105.280815;
    PD 433.155793838099,6809.96926531645;
    AR-92.078401,282.457302,154.639235;
    PD 378.853805367389,7387.10181510187;
    AR44.126773,115.362399,-89.15119;
    PD 306.977144728057,7544.87716734709;
    AR2426.264900,-4.825061,-14.992397;
    PD 390.815007224101,8172.36549365287;
    AR147.987649,-87.169005,-76.507269;
    PD 589.036981001322,8249.43805546249;
    AR-3.807935,368.152606,171.964711;
    PD 632.919968580574,8982.66108877585;
    PD581.129208,9030.447879;
    PD566.006392,9117.256022;
    AR111.113783,-47.256241,-96.833174;
    PD 737.260937277178,9174.70180485217;
    AR11.498453,296.432695,164.642069;
    PD 838.356890114032,9753.93627711772;
    AR80.509063,108.855561,-84.978967;
    PD 803.381841752111,9933.46476344573;
    AR5047.899309,-1709.130992,-7.103799;
    PD 1053.4943969832,10544.6049725247;
    AR1282.086573,-815.189179,-104.379296;
    PD 3443.62590029627,10768.89  LVAL   _  44180892;
    PD3671.834305,10544.155379;
    AR-140.120221,-87.145263,-85.757807;
    PD 3628.98565077943,10323.7201482879;
    AR260.934551,-140.153514,160.773765;
    PD 4090.14889169198,9965.30459100546;
    AR56.560055,-123.706359,-90.682087;
    PD 4271.07985275966,9896.68163163507;
    AR-6602.277462,-5383.201969,-10.232467;
    PD 5122.35629855291,8638.21786855666;
    AR-132.477894,-92.106348,-100.674802;
    PD 5055.85132229478,8398.86497359036;
    AR223.826292,-190.664424,153.909192;
    PD 5396.8423132336,7938.52748027472;
    AR-20.658581,-196.289085,-76.433903;
    PD 5571.84216587689,7768.19911974752;
    AR-8477.076479,-3685.578933,-12.943089;
    PD 6181.97274834273,5775.83769296989;
    AR-185.694258,64.121350,-60.194691;
    PD 6032.93929238961,5646.95673555449;
    AR157.646690,-247.261898,152.110709;
    PD 6214.2621247448,5107.41010526138;
    AR-37.756079,-147.904290,-88.004823;
    PD 6325.63516282003,4926.92196813713;
    AR-10376.422876,-720.175570,-10.62103;
    PD 6280.60093125264,3002.08327867115;
    AR-125.868054,48.098431,-83.302809;
    PD 6121.64164160018,2919.56319554911;
    AR36.102197,-294.718199,165.644599;
    PD 6119.64758536974,2330.37791790207;
    AR-71.597219,-119.171800,-91.893905;
    PD 6164.7908603901,2135.70951752732;
    AR-2402.783361,662.652978,-25.508116;
    PD 5645.21367423642,1165.56999442387;
    AR-68.711073,115.972433,-92.916245;
    PD 5457.1846042288,1218.82056199718;
    AR-230.905545,-271.448944,172.018944;
    PD 4959.92054582114,710.612156791503;
    AR-143.412786,-51.664398,-100.778626;
    PD 4840.44032474913,508.403182609259;
    AR-113.124335,164.120976,-62.046674;
    PD 4635.370325394,495.666010293062;
    PD4571.525941,599.748341;
    AR-231.888957,-167.209912,148.841006;
    PD 4054.68466993848,409.433845892282;
    AR-158.264418,8.638548,-105.407249;
    PD 3846.04476923675,267.79078755668;
    AR-28.422633,83.487756,-101.421186;
    PD 3730.15935830562,339.950963762671;
    AR-118.422246,-0.304412,81.496847;
    PD 3628.94641410098,456.812080240125;
    PD3046.642721,588.420445;
    PD2993.658943,577.076260;
    PD2903.230281,465.527837;
    PU3497.239433,73.989732;
    PU 3497.23943LVAL        X    X     PU 321.934334,294.686737;
    CI 141;
    PU 2638.295159,337.134025;
    CI 142;
    PU 2601.435488,3027.422026;
    CI 142;
    PU 292.771080,2970.233969;
    CI 140;
    PU2439.491478,2672.171844;
    PD1518.354442,2645.079604;
    AR-671.648797,32619.649487,-2.022134;
    PD 366.933263169467,2641.69331529568;
    AR-16.368216,-94.258758,104.250031;
    PD 255.177458608116,2540.09698268725;
    PD268.723592,799.419001;
    AR149.    3,73.989732;PD;
    AR325.003593,1558.757673,15.85322;
    PD 3935.41296449409,44.4951002258094;
    AR-267.151114,4159.349538,7.292543;
    PD 4461.22113991216,112.051160819142;
    AR-756.522907,2656.058523,54.141477;
    PD 6300.50349918186,1825.36432744446;
    AR-4951.713699,1572.425929,14.234345;
    PD 6535.11801989725,3091.20999741099;
    AR-9291.745480,980.482212,29.426631;
    PD 5818.06792812813,7782.8212058482;
    AR-8759.328334,-3770.691633,23.201591;
    PD 3624.12229210538,10928.7543483156;
    AR-1280.727860,-1190.892862,110.209957;
    PD 783.379373020724,10528.331394929;
    AR7528.959841,-3285.222222,14.1577;
    PD 208.524802205216,8587.02632584919;
    AR11221.965635,-1869.054363,18.222812;
    PD 186.85524578506,4984.03291947118;
    AR9053.100082,1507.145265,10.554812;
    PD 616.105544500592,3351.22231510168;
    AR11234.073331,4185.236845,10.232156;
    PD 1538.22469524397,1422.19615949136;
    AR2331.092389,1251.890957,41.413441;
    PD 2949.21117956378,193.234880068562;
    PD3030.757689,157.996293;
    AR19.580727,84.970009,58.920982;
    PD 3113.00354817813,182.333072592306;
    PD3172.295318,313.879093;
    AR34.606750,-30.712601,-50.033787;
    PD 3208.21176953171,329.417715634035;
    PD3430.118750,282.745289;
    AR-21.363658,-33.981806,-73.024448;
    PD 3447.49370214355,238.252103152029;
    PD3444.566428,136.713879;
    AR64.790961,3.507242,76.688193;
    PD 3497.85225980725,76.3634560254008;
    PD3497.239433,73.989732;
    PU0,0;SP0;  LVAL   a  PU 588.315562,1039.127490;
    CI 181;
    PU 2164.363097,834.420392;
    CI 171;
    PU 3101.938041,468.731155;
    CI 180;
    PU 4384.249203,2696.539553;
    CI 139;
    PU 5204.080641,5004.851615;
    CI 139;
    PU 5047.805636,7518.254276;
    CI 141;
    PU 2364.027399,8121.555131;
    CI 141;
    PU 801.571462,7720.959697;
    CI 140;
    PU 612.821459,9285.219777;
    CI 143;
    PU 3612.279723,12612.884668;
    CI 139;
    PU 4798.300166,12759.127735;
    CI 172;
    PU 6121.650812,12349.103015;
    CI 182;
    PU 6778.389615,9767.592852;
    CI 141;
    PU 3158.167860,13960.786143;
    CI 180;
    PU 615.865909,5614.537488;
    CI 139;
    PU 825.620828,3483.922456;
    CI 141;
    PU721.569745,9986.147457;
    PD712.011717,9915.528579;
    AR234.526928,5.860222,60.179372;
    PD 834.995854948921,9715.00220224265;
    PD1817.232498,9259.067364;
    AR-169.531170,-482.676963,-25.671219;
    PD 2009.59762911025,9137.98262361435;
    AR2230.324371,1037.209530,68.755439;
    PD 4398.48806575688,7720.60314316785;
    AR-205.317708,2330.606587,88.27324;
    PD 6528.9054618573,10186.2058348054;
    AR-2309.438582,-108.303521,91.309298;
    PD 4058.42195202138,12384.2632456762;
    PD3741.062334,12336.609115;
    AR-217.111605,485.000274,-39.161423;
    PD 3386.01126433687,12308.4472129833;
    PD2307.928380,12809.689518;
    AR-116.694620,-232.163426,79.43752;
    PD 1984.39521951866,12734.8007208521;
    PD1802.860031,12825.639467;
    AR-62.593353,-130.272004,91.907239;
    PD 1607.98364447696,12753.590498887;
    AR-111102.728459,50563.120273,-1.277477;
    PD 453.098098967879,10289.1967678624;
    AR110.895370,-74.194267,95.794061;
    PD 501.373486788848,10097.1835290231;
    PD721.569745,9986.147457;
    PU1004.827034,3709.577608;
    PU 1004.827034,3709.577608;PD;
    AR-191.374676,-226.711970,-128.72511;
    PD 870.602079592712,3191.73595336227;
    AR240.634625,-234.490840,38.696943;
    PD 776.826187464442,2989.81170508932;
    PD521.328526,1520.832754;
    AR122.254209,-16.257674,100.436032;
    PD 649.738840210674,1381.39835350209;
    AR-66.051946,-368.402537,-98.500402;
    PD 938.278907019491,893.213544512889;
    AR150.079224,-2.568031,89.284703;
    PD 1083.91671705547,740.610044548672;  LVAL   b
    PD1624.934946,630.608251;
    AR15.670243,162.895397,97.960534;
    PD 1804.10106373171,800.54394807734;
    AR443.010979,-10.895093,-54.616466;
    PD 1999.47061887709,1157.14192413707;
    AR159.519651,-317.137253,-122.747102;
    PD 2512.01302256462,802.621618778431;
    PD2470.667127,527.332950;
    AR137.412569,23.921954,83.166823;
    PD 2615.48252763306,411.97219837518;
    AR15.585579,123.887236,105.489419;
    PD 2754.61802332231,553.92530269521;
    AR345.846499,-74.490652,-111.89367;
    PD 3298.5437846366,772.561353214133;
    AR51.787561,113.310156,93.267664;
    PD 3466.40919714452,840.626891752693;
    PD4226.377459,2320.742016;
    AR-125.622974,67.787207,88.719703;
    PD 4171.33163081759,2512.60622940211;
    AR214.029763,191.863516,-133.692407;
    PD 4394.48170176971,2991.76257145358;
    AR-54.794890,154.217976,67.093557;
    PD 4503.07109119649,3136.42851905016;
    PD4991.472629,5409.965976;
    PD5003.169129,7181.812284;
    AR-188.633730,-60.499774,55.476358;
    PD 4871.59755370553,7311.01442682776;
    PD4728.822162,7487.393034;
    PD4653.962915,7502.677352;
    AR-412.900977,2551.862860,-29.666469;
    PD 3336.79527164611,7632.80672765946;
    AR1087.522221,3110.132503,-12.985983;
    PD 2665.72238379162,7956.72818153836;
    AR49.798545,-349.465959,33.458552;
    PD 2481.30242923243,7871.36077590901;
    AR-111.487835,266.978251,-151.000636;
    PD 2142.87350368082,8317.79561084456;
    AR-133.037538,86.901031,83.539731;
    PD 2111.15379879352,8527.11180611817;
    AR1710.044901,1399.993458,-13.78037;
    PD 1826.89636608366,8974.74322822262;
    PD1737.597325,9030.356802;
    PD1282.739050,9226.943652;
    AR6.092848,-179.736204,81.638817;
    PD 1110.1201186926,9067.31530123861;
    AR6890.293255,-2494.532472,7.988139;
    PD 830.317175105102,8085.57954296404;
    AR200.506502,74.240783,54.687899;
    PD 975.506539089842,7953.29050873055;
    AR-172.485843,-223.230444,-143.536768;
    PD 796.968329602866,7448.02005731395;
    AR46.781830,-189.310916,78.187721;
    PD 648.871665264341,7251.67103184368;
    AR8488.321206,-1220.506554,8.504918;
    PD 561.710303564767,5982.87498295738;
    AR167.771974,76.036144,64.751078;
    PD   LVAL   c  726.690745217913,5874.73420675348;
    AR-95.537650,-260.383764,-155.156036;
    PD 653.856793123576,5337.9237996982;
    AR85.895887,-160.533610,80.482587;
    PD 567.226095127865,5119.2204320722;
    PD746.564025,3900.343094;
    AR157.358865,12.296617,86.138826;
    PD 905.595174876169,3754.80998424669;
    PD1004.827034,3709.577608;
    PU207.907615,1141.304609;
    PD604.820203,3416.209294;
    AR9394.841519,2427.330956,-16.91675;
    PD 305.039167894752,6254.97222556332;
    AR9265.527569,-338.359005,-15.35487;
    PD 725.375222949985,8696.37490675583;
    AR-176.508491,114.175948,109.83168;
    PD 596.38934960135,9015.32633046328;
    AR10.931006,281.969957,-116.648116;
    PD 360.204503787852,9433.53247483448;
    AR-94.938304,120.482654,97.643543;
    PD 372.050624791542,9664.13523662264;
    AR171.264550,425.001969,-51.202576;
    PD 104.774013410314,9956.32203471183;
    AR722.904623,80.921615,-38.707885;
    PD 212.959758506749,10426.1653681334;
    PD1432.943323,13010.552101;
    AR374.332170,-160.929964,-82.652664;
    PD 1919.01297222547,13241.4610867565;
    AR82.999015,143.465961,85.250075;
    PD 2138.11233894247,13290.3331121997;
    PD2832.765457,14199.929765;
    AR333.845502,-246.740733,-79.477963;
    PD 3348.23792441973,14326.4790719949;
    PD4994.005805,13427.898760;
    PD4913.324469,13246.587509;
    PD5150.002738,13112.931356;
    PD5250.998411,13294.690237;
    PD6286.561578,12724.762969;
    AR-164.197407,-362.120448,-73.739797;
    PD 6515.97507336329,12306.4067239842;
    PD6377.744767,11663.144762;
    AR529.403313,-159.307860,17.843625;
    PD 6354.39585202446,11493.2616222766;
    AR-2028.186464,-1361.482400,-30.088277;
    PD 6763.66289331573,10293.0090844298;
    AR285.017682,-41.199869,49.770832;
    PD 6833.14816642884,10060.8163120711;
    AR-80.063746,-285.318278,-147.485413;
    PD 6838.93295302937,9491.86666642871;
    AR-21.324013,-137.015184,95.473727;
    PD 6679.18445606452,9363.00847549661;
    AR-2620.936440,772.567879,-42.942586;
    PD 5450.54620745782,7784.47561268402;
    AR445.461312,-1152.031350,8.797411;
    PD 5279.59389340073,7702.7929225083;
    PD5279.728569,7082.909425;
    AR-26505.345326,-47.429713,LVAL         @        a   Xd   X d   X4  X49244,576.665148946682;
    AR-93.303501,128.843777,66.210877;
    PD 3184.70661899117,738.913093388458;
    PD3183.434703,1415.651092;
    PD3278.431947,1509.630754;
    AR-1163.534781,1314.845492,93.314697;
    PD 3360.26723519685,4062.0889661908;
    PD3138.719716,4269.559654;
    PD3108.655874,5009.082780;
    AR-211.560945,-56.535411,70.040157;
    PD 2916.17423334641,5170.69930296321;
    AR-761.612308,-2116.219555,32.420356;
    PD 1662.90556105296,5249.18076017086;
    AR28.057662,-224.836964,46.885843;
    PD 1507.65759111734,5157.52764701656;
    AR4931.156833,-1670.913814,8.056528;
    PD 1322.14811162227,4449.93440899513;
    AR-175.381670,35.771223,-61.602892;
    PD 1198.70745882428,4314.41511502367;
    AR1011.375600,-1536.515945,48.547302;
    PD 388.928336624253,3037.04648546227;
    AR1760.284051,-205.556493,69.870863;
    PD 1350.43216611264,1249.46484344708;
    AR-6949.031399,-2503.395965,-6.150869;
    PD 1578.65898714774,490.486599473752;
    AR170.796437,75.650329,64.077195;
    PD 1742.82877197    -2.682127;
    PD 5252.91198289332,5842.54375444465;
    PD5253.218634,5368.320448;
    AR273.484083,106.479784,42.181633;
    PD 5395.54494564295,5212.25666024916;
    AR-200.895651,-201.938657,-139.599182;
    PD 5172.54407822227,4726.32919489296;
    AR70.705079,-154.300978,60.905921;
    PD 5074.03749755187,4585.27262149773;
    PD4655.510240,2675.725509;
    AR-2413.933477,753.177275,-12.005252;
    PD 4446.05209565406,2190.09717104957;
    PD3451.655590,281.386989;
    AR-354.388515,171.998929,-80.099454;
    PD 2988.76263315098,74.7018316693427;
    PD2178.733989,249.749253;
    PD2221.843759,443.930866;
    PD1965.815809,519.532680;
    PD1923.280957,312.007793;
    PD466.200553,642.289975;
    AR131.843166,377.864971,-54.948863;
    PD 212.989922445543,911.076394081059;
    AR753.498975,131.803760,-17.314642;
    PD 207.907614830259,1141.30461297794;
    PU0,0;SP0;  LVAL   e  PU 387.459701,379.987583;
    CI 132;
    PU 385.255617,1377.274737;
    CI 135;
    PU 2015.210680,1970.307606;
    CI 131;
    PU 3645.249765,396.952116;
    CI 133;
    PU 3656.135784,1387.318787;
    CI 129;
    PU826.832249,1068.796991;
    PD838.482484,1305.010796;
    AR159.352675,17.548136,-104.048512;
    PD 1019.49368074598,1481.40514864525;
    AR219.451350,-3382.488514,-10.230144;
    PD 1623.72091137263,1466.60649036878;
    AR-39.532956,-133.779573,-79.119337;
    PD 1723.02490283266,1319.25743628756;
    PD1717.523154,421.172250;
    AR-134.096503,-22.982125,-94.567182;
    PD 1595.65796688157,262.68940508254;
    AR-254.032765,2723.549701,-14.446464;
    PD 908.167429757821,285.429971928544;
    AR71.859665,133.473997,-63.479971;
    PD 828.511350593478,423.604881665263;
    PD824.490672,882.522030;
    PD826.832249,1068.796991;
    PU2304.813868,685.120038;
    PD2312.453362,700.231529;
    AR980.761379,-133.891614,19.661242;
    PD 2324.58441236411,362.440103121132;
    AR166.063583,96.743814,64.782788;
    PD 2507.42046678557,267.728535273871;
    AR259.356619,2320.050702,14.839094;
    PD 3110.24777114073,278.682226703724;
    PD3164.991303,328.418785;
    AR-999.545990,251.516200,16.721601;
    PD 3195.09123580228,626.645354771222;
    PD3192.348052,1373.315105;
    AR-153.734347,-56.476414,81.668903;
    PD 3005.00833757684,1477.13377534812;
    AR-155.321895,-3662.075505,9.681052;
    PD 2386.96937599889,1451.10211100515;
    AR110.439754,-132.744209,56.369181;
    PD 2325.71729087818,1299.92215771889;
    PD2318.335039,1001.594679;
    PD2304.813868,685.120038;
    PU3991.261290,521.638149;
    PD3992.058933,1383.395246;
    AR-327.808047,5.387234,92.15383;
    PD 3657.31444447888,1716.56140511135;
    PD2616.820329,1712.093467;
    AR22.675570,295.699014,-90.758876;
    PD 2344.12314794409,2034.38244694698;
    AR-320.732425,-49.565329,125.527151;
    PD 1796.67848235217,2217.04022232982;
    AR609.414134,-461.636837,27.998705;
    PD 1651.28925248489,1876.91897369501;
    AR-284.354574,157.582533,-64.942387;
    PD 1344.61595392221,1710.168879303;
    PD360.198328,1714.539442;
    AR21.839335,-331.585300,86.793754;
    PD 49.7499208290442,1379.6946739052LVAL 7        X    X`   X`   XXH       X            3        MhZz    &   8;%       BB   e         e              3        hZz    &   ;%    U   X0CX0C      U   U   U              3       PWhZz    &   ;%       8C8C                          3         hZz    &   4;%       CC                          3         hZz    &   ;%       HCHC                          3         hZz    &   ;%       CC                          3         hZz    &   0;%       xDxD                          3         hZz    &   ;%       DD                          3         hZz    &   ;%       DD                          3         hZz    &   ,;%       DD                          3         hZz    &   ;%       DD                          3         hZz    &    ;%       DD                          3         hZz    &   (;%        E E                          3         hZz    &   |;%       EE                                    H@     H@      .@     7  9x!6c@   BKL@׍.6c@3HusqvarnaSet3Da   `      AbaaUTSROFE           H@     H@      .@     *  9x!6c@   BKL@׍.6c@2HusqvarnaSet2DaG   ]      AbaaUTSROFE           H@     H@      .@   0  h  _!6c@   ŨKL@׍.6c@1Husqv    7;
    PD43.643018,345.305655;
    AR371.174966,73.947631,83.561009;
    PD 446.67365509938,42.1268831396043;
    PD3086.488042,44.038180;
    PD3693.885385,61.030300;
    AR-35.137603,327.018066,83.132741;
    PD 3987.62115132022,383.832492789199;
    PD3991.261290,521.638149;
    PU0,0;SP0;vLVAL       N              *  *
             w)
           (g                      $  
                        (           0
             Nf          4           <
             2 IDGasket #MakeModel    From YearTo YearGasketMaterial    ThicknessGasketsInSetCommentsMaxXMaxYhpglhpgldatetimeCutQtyOEMcreateddatewebdateInSet          *  +              *  ,              *  -                  *  .              *  /                  *  PU 1516.726214,287.094325;
    CI 105;
    PU 2877.194136,1506.121174;
    CI 106;
    PU 1640.285512,2859.926974;
    CI 105;
    PU 289.242880,1604.361310;
    CI 104;
    PU 1581.503019,1567.543664;
    CI 1045;
    PU2188.647964,2789.405954;
    PD1839.835242,3033.236122;
    AR-201.498662,-264.826813,74.532804;
    PD 1436.837917002,3033.23612124065;
    AR1656.324909,-3387.906120,14.236226;
    PD 654.548734162431,2521.8698312166;
    AR2995.235170,-2825.187741,13.851276;
    PD 65.2920110298357,1722.64787573864;
    PD48.359606,1593.959253;
    AR2503.613434,904.313545,14.447323;
    PD 353.147305580773,997.929969100056;
    AR1701.454975,990.971751,27.513369;
    PD 1003.36156322242,324.009231655173;
    PD1369.107316,70.019238;
    AR162.399511,289.933160,66.981557;
    PD 1734.85256814858,97.1114803380835;
    AR-1323.935086,2853.571286,19.426727;
    PD 2608.5786854073,699.914357272031;
    AR-4474.133239,3800.754642,8.476397;
    PD 3119.94498429457,1400.92732520674;
    AR-323.948374,91.346556,54.362223;
    PD 3058.98690680699,1702.32826978718;
    AR-4808.213797,-2477.678009,9.486505;
    PD 2584.87268742615,2460.91185178452;
    AR-1967.068608,-1969.441673,10.609375;
    PD 2188.64791492246,2789.40600401781;
    PU0,0;SP0;aLVAL m7W @        vfw`   X vfwb   XW   XX   XY   X[   X       M       M       M       M       M       M           M
           M       M       M
           g        g       g       g       g       g       g       g       g       g           g
    d_   g    afuv   gs`uwpxoafuv   gs`uwpxoafuv   gs`uwpxoafuv   gs`uwpxoafuv   gs`uwpxoafuv   g @       22007201wwoccbXUME    {W       H@     L@      .@
      S4M@   '}R4M@8e|4M@22007201Husaberg501Water PumpD @       22007201wwoccbXUME    {V       H@     L@     PU 405.567379,368.759211;
    CI 113;
    PU 394.417336,1938.288656;
    CI 112;
    PU 1985.652965,1963.832603;
    CI 111;
    PU 2003.302355,377.866824;
    CI 111;
    PU1180.375298,1947.198614;
    PU 1180.375298,1947.198614;PD;
    AR27.117866,-786.047334,-190.146577;
    PD 1095.71131989914,382.620221355381;
    AR85.578803,776.027628,-162.128859;
    PD 1024.59442729407,1923.49363041946;
    PD1180.375298,1947.198614;
    PU2253.905946,372.461359;
    PU 2253.905946,372.461359;PD;
    AR-7621.269436,1196.847461,6.197086;
    PD 2338.56895844521,1202.16203598964;
    PD2230.199993,2025.089049;
    AR-256.935407,-73.363363,78.520332;
    PD 1952.50416076512,2218.12199067593;
    AR-1255.503584,-9626.217882,4.7769;
    PD 1146.50950233788,2289.23888100752;
    PD337.128030,2174.096373;
    AR43.964874,-239.806759,80.556648;
    PD 137.322512024809,1930.26620696348;
    PD56.045789,1161.523630;
    PD161.028465,314.889620;
    AR238.211623,50.135317,75.450797;
    PD 387.926224618511,121.857661573454;
    PD1112.644696,33.807391;
    AR-301.624548,7063.731078,6.762632;
    PD 1942.3452420573,118.471365022887;
    AR31.142655,304.606438,58.413164;
    PD 2216.65385121955,236.999148333541;
    PD2250.519659,335.209285;
    PD2253.905946,372.461359;
    PU0,0;SP0;
    I'm not sure there is anything more I can do for you on this, sorry.
    .Me
Name:	Gasket dlux 04-08.png
    .Me
    Forgot to add this, this is the Water Pump Gasket itself.
    .Me
    .Me
    Hi Lee,
    Sorry I never thanked you for your help, it was very helpful !
    Cheers,
    Jamie
  7. The Following User Says Thank You to greenz123 For This Useful Post:
  8. #7
    Cool np, did you manage to get any ware with it though?
    .Me
  9. #8
    I didn't but passed on the info to someone who might ! I know nothing about VB scripting/projects. But at least they have a starting point.
  1. Create dxf file.
    By Tanky_Turk in forum CAD & CAM Software
    Last Post: 10-02-2014, 09:03 PM
  2. File upload problems - attachments file extension support !
    By Swarfing in forum General Discussion
    Last Post: 08-03-2013, 01:37 PM
  3. Heavy Duty Extension Spring
    By Stevetechguy in forum Manufacturer News
    Last Post: 17-10-2012, 03:45 PM
  4. Limiting unsupported extension on Zaxis.
    By Rogue in forum Gantry/Router Machines & Building
    Last Post: 02-09-2011, 11:30 PM
