Thread: CNC Hotwire 4 axis foam cutter
04-06-2015 #1
Hi there!
I will be building a 4 axis CNC hotwire maching for cutting cores for Radio Controlled gliders.
I am just starting the serious research (when I am not being seconded into the real world) and so far I'm thinking that due to my current space constraints I will make it so that it holds the foam vertically against the garage wall.
The machine size is still up in the air and will depend on the size of the blocks I can source. The largest wing panel I can see myself making is 1500mm, although being CNC made (accurately compared to wire dragged over templates/fences) I could make the panels in 2 parts as the majority of the wing panels would be 750mm.
I have a LOT to learn as I am trying to teach myself CAD (Onshape and Sketchup), am yet to learn anything about CAM and have always been petrified by Electrickery!!
I have chosen to build a CNC hotwire as it should be relatively simple and I want to build a CNC router next, having learned some lessons along the way.
The basic idea of the CNC Hotwire machine is to enable me to cut eliptical wing panels which requires independent movement of each end of the wire along the x axis and z axis (hopefully got them right from a gantry machine perspective)
The x axis travel shouldn't need to be more than 500mm and the z axis travel should be similar. I do need to figure out if I would need more though. If, for example, I was to cut a 750mm panel with an elliptical shape and the posts were 1500mm apart, the x axis travel would need to be much greater than if the posts were 800mm apart. Perhaps I need to look at designing my machine to have relocatable rails for the x axis?
I understand that from a construction point of view, my two machines will be worlds apart, the lessons I'm hoping to take to the next build will hopefully be software, electrical and generic.
Anyway, gotta go do the school run.
ClaytLearning, learning, learning! !!
CNC Router Build TBA
04-06-2015 #2
Just re read above and it read like i was planning to have the foam on the wall. I meant the machine BASE against (or leaning onto) the wall.
11-06-2015 #3
After some computer issues, I can get going on the learning side of things again.
I found Autodesk Fusion 360 (thanks again to the info here) which integrates CAD and CAM so have started using it. I'm brand new to Macs so am still learning the in's and out's of screen shots etc.
I won't be having the foam cutter anything other than flat as it wouldn't be possible to keep the foam block and the cut part in the correct position at the end of the cuts and would cause damage to the parts. With the block flat, I can use double-sided tape and gravity.
Better keep drawing, hopefully have some info and pics for you soon.
12-06-2015 #4
12-06-2015 #5
12-06-2015 #6Learning, learning, learning! !!
15-06-2015 #7
Sorry can't help you with any info on the 4 axis hot wire but Silyavski may have a point depending on what you want to do. If you need to cut a lot of wing profiles rapidly the hot wire is obviously the way to go but if time is on your side then simple 3 axis milling is not such a bad idea as it gives you a lot of options that hot wire can't do. A relatively flimsy but fast 3 axis router dedicated to foam cutting should be easy to build.
Had to dig around to find the model but several years back I did cut a few gliders for a friend on my router. He asked me to cut two wing profiles and I suggested we cut the whole aircraft in one go. The entire model including the fuselage was cut from one big piece of foam with a two sided strategy excluding the wing tips which were glued on afterwards. The screenshots below shows the model I drew using his wing profile. I know sh%t about aerodynamics so I just went with a sort of a teardrop shaped thing for the fuselage so he's got somewhere to put the battery and receiver:-) The white round bits you see on the wings are just supports used when I turned it over to cut the bottom profile. The piece of foam was bigger than the model so it was supported at the wingtips as well.
Don't think I have any pics of the actual cut models but apparently they flew very nicely :-)
15-06-2015 #8
Nice work on the glider Mitchejc. I agree that a router would be much more versatile and I will be making one to go along with the hotwire. One of the crucial things with supplying wing cores for people to finish is to also supply the beds. A router cuts the beds into little bits that are really hard to put back together ;-)
I'm aiming to produce 3 types of glider from foam as kits and hopefully the funds from them will help me to make my 'aluminium capable' router for making parts and moulds for composite gliders.
Prototypes for the composite gliders will be routed as you suggested above, especially the fuselages.Learning, learning, learning! !!
16-06-2015 #9
17-06-2015 #10
Thanks for that. Some rene on its way. Power supply is going to take some thought. It will need to be adjustable as the foam types and sizes will differ regularly.
Design of the machine is coming along slowly (the drawing is the slow bit, the design is evolving in my head)Learning, learning, learning! !!
foam cnc carver- deep z axis - 4x4 bed
By marbles in forum Hotwire Cutting MachinesReplies: 9Last Post: 17-05-2016, 09:20 AM -
Hot Foam cutter for RC aircraft
By rckeith in forum Hotwire Cutting MachinesReplies: 25Last Post: 10-08-2015, 08:32 AM -
FOR SALE: CNC 4 axis Foam Cutting Machine
By Am1707 in forum Items For SaleReplies: 1Last Post: 25-06-2015, 01:43 PM -
NEW MEMBER: First post - want to build a cnc hot wire foam cutter
By rckeith in forum New Member IntroductionsReplies: 8Last Post: 12-12-2010, 12:23 AM -
Software for foam cutter - any recommendations
By rckeith in forum Machine Control SoftwareReplies: 2Last Post: 08-08-2010, 10:14 AM
