Page 2 of 2 FirstFirst 12
    no probs..if you really do want to cut wings 1500mm long have a thought for the volts required ( its probably gonna be 50v +), which of course depends on the wire your using ( its probably gonna be 50v +),
    Here is an interesting web site re wire choice http://www.jacobs-online.biz/nichrome/NichromeCalc.html
    I use rene 41 wire, its strong and doesn't really weaken or stretch when it gets hot.
    Again a site worth looking at is http://www.jacobs-online.biz/nichrome_wire.htm , http://jacobs-online.biz/rene_wire.htm and http://www.skykingrcproducts.com/acc.../renewire.html
  2. The Following User Says Thank You to jregholdsworth For This Useful Post:
  3. #12
    Thanks for that. Some rene on its way. Power supply is going to take some thought. It will need to be adjustable as the foam types and sizes will differ regularly.
    Design of the machine is coming along slowly (the drawing is the slow bit, the design is evolving in my head)
    Learning, learning, learning! !!
    CNC Router Build TBA
  4. #13
    I built an arduino controller that uses PWM to control the wire heat...others use dimmers and transfromers...bit dubious about the safety of that though. The original idea was from Ufoman
    http://diydrones.com/profiles/blogs/...age=2#comments
    I improved on this to give a heat read out and manual control mechanism, the option to drive it automatically from Mach3 or GMFC
  5. #14
    Arduino sounds pretty useful, but I think it might be one too many things to learn from scratch for this project. I'll see how expensive an appropriate power supply and heat controller are and then decide if I need to take the Arduino learning route.
    Thanks again
  6. #15
    I'll be following this with interest as I want to build a cnc hot wire cutter to make my own wings...
    Neil...
    Build log...here
  7. The Following User Says Thank You to njhussey For This Useful Post:
  8. #16
    I've been playing with fusion360 and have come up with a bit of a design.
    I've designed it so that when I'm not cutting cores I can utilise a flat surface for other projects so have gone a bit over the top with regards to the structure.
    The idea is that the runners are interchangeable on the supported rails to enable some flexibility in the length of the cutting wire and it will be tensioned with a weight over a pulley.
    The vertical axis will have a little bit of lateral force applied to them as the bases move independently. To deal with this, I am aiming to use hiwin rails for the vertical block.
    There is hardly any force required to pass the wire through the foam, so I am planning on running belts and pulleys to control the axes (as per printer).
    My drawing isn't very good and doesn't allow me to change and modify things (still learning CAD on the fly) but I am also aiming to do some epoxy levelling to the frame before mounting the rails and plates.
    The way it is drawn at the moment gives a max effective cutting area of 2100mm long x 550 wide x 170mm high.
    Just looked at the clock and I am about to be late for work! Gotta go! Sorry if it's a bit disjointed (The post) hopefully you get a little bit of an idea about my project.
Name:	hotwire cnc capture 1.jpg
  9. I've built a 4 axis hot wire machine you can see my build and plans at http://www.rckeith.co.uk and have used it to produce wings and fuselages. I don't really have a limit to the size of wing as the two towers can just be moved further apart. I usually secure them to a board to prevent them moving. I've found the best result are obtained with really thin wire( I think the size is on my website). If your wire is long then you may need to experiment with feeds and current as it may vibrate a little and give poorer results. The biggest challenge I've found is the software. Not much around for 4 axis hot wire so tends to be more expensive. I've spent more on software than hardware. I use Profili2 Pro and Dev Fus Foam but its a bit of a learning curve. Straight wings are fairly easy but tapered are bit more challenging. If you don't have positioned correctly in the machine according to the distance specified in the software the wing comes out larger or smaller. My first flying wing came out a bit smaller than I expected but it was a bonus because if flies absolutely fantastic. Hope that helps
    Keith
    Quote Originally Posted by Skipsoaring View Post
    Hi there!
    I will be building a 4 axis CNC hotwire maching for cutting cores for Radio Controlled gliders.
    I am just starting the serious research (when I am not being seconded into the real world) and so far I'm thinking that due to my current space constraints I will make it so that it holds the foam vertically against the garage wall.
    The machine size is still up in the air and will depend on the size of the blocks I can source. The largest wing panel I can see myself making is 1500mm, although being CNC made (accurately compared to wire dragged over templates/fences) I could make the panels in 2 parts as the majority of the wing panels would be 750mm.
    I have a LOT to learn as I am trying to teach myself CAD (Onshape and Sketchup), am yet to learn anything about CAM and have always been petrified by Electrickery!!
    I have chosen to build a CNC hotwire as it should be relatively simple and I want to build a CNC router next, having learned some lessons along the way.
    The basic idea of the CNC Hotwire machine is to enable me to cut eliptical wing panels which requires independent movement of each end of the wire along the x axis and z axis (hopefully got them right from a gantry machine perspective)
    The x axis travel shouldn't need to be more than 500mm and the z axis travel should be similar. I do need to figure out if I would need more though. If, for example, I was to cut a 750mm panel with an elliptical shape and the posts were 1500mm apart, the x axis travel would need to be much greater than if the posts were 800mm apart. Perhaps I need to look at designing my machine to have relocatable rails for the x axis?
    I understand that from a construction point of view, my two machines will be worlds apart, the lessons I'm hoping to take to the next build will hopefully be software, electrical and generic.
    Anyway, gotta go do the school run.
    Clayt
  10. #18
    Thanks Keith. Things are a bit stop-start at the moment, with more stopping than starting.
    This affects my focus and I find myself drifting off-target and 'considering' getting a cnc converted Mill (or converting one). Imaginations hey? Where would we be without one!
  11. #19
    550mm travel is a little tight imo ... when doing high taper cuts the one side can travel alot more than you think
    just a thought :D
  12. #20
    Thanks for your inputs so far guys.
    I have had a re-think and decided that I am not going to ruin my RC Hobby by trying to make any money out of it and therefore won't be needing to make large quantities of wing cores. So I won't waste my time, effort and money on building a CNC hotwire machine.
    I will however, be building a CNC router although I think I need to build a shed/workshop first. Integral garage directly below my son's bedroom and attached to the living room will restrict the noises I can make.
  1. foam cnc carver- deep z axis - 4x4 bed
    By marbles in forum Hotwire Cutting Machines
    Last Post: 17-05-2016, 08:20 AM
  2. Hot Foam cutter for RC aircraft
    By rckeith in forum Hotwire Cutting Machines
    Last Post: 10-08-2015, 07:32 AM
  3. FOR SALE: CNC 4 axis Foam Cutting Machine
    By Am1707 in forum Items For Sale
    Last Post: 25-06-2015, 12:43 PM
  4. NEW MEMBER: First post - want to build a cnc hot wire foam cutter
    By rckeith in forum New Member Introductions
    Last Post: 11-12-2010, 11:23 PM
  5. Software for foam cutter - any recommendations
    By rckeith in forum Machine Control Software
    Last Post: 08-08-2010, 09:14 AM
