Thread: Cooler probe
    I need the attached part made. This is part of a cooler and will be fitted with a peltier device on the back it needs to have good thermal conducting properties in water such as aluminium. It is going into a freshwater aquarium and needs to be water resistant and not leach any chemicals into the water/react with water. Can you suggest a material and/or coating suitable for this application? Only the cylindrical part needs to be coated if required. 30 is my budget for this project. Is this do able? Is there a better/cheaper way to make this? http://www.docdroid.net/132ev/probe-1.pdf.html
    Thank you
    Daniel.
  1. CNC3040t probe tool
    By wesk18 in forum General Electronics
    Last Post: 04-12-2014, 04:40 PM
  2. Touch Probe Project
    By Washout in forum Tool & Tooling Technology
    Last Post: 20-11-2013, 11:59 AM
  3. Touch Probe
    By luke11cnc in forum Probing, Digitizing & Scaning
    Last Post: 31-01-2012, 12:16 AM
  4. RFQ: Touch Probe - Lathe job
    By cooliced in forum Projects, Jobs & Requests
    Last Post: 16-11-2011, 06:12 PM
  5. DIY CPU water cooler
    By wiatroda in forum Electronic Project Building
    Last Post: 06-04-2011, 10:44 AM
