Page 21 of 25 FirstFirst ... 111920212223 ... LastLast
  1. Can you post a few pics of the mill in position. Nice idea with the castors. Will do the same to mine I think . What kind of rapid feedrates are you getting on the machine?
  2. #202
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Hours Ago Has been a member for 5-6 years. Has a total post count of 1,213. Received thanks 90 times, giving thanks to others 59 times.
    Quote Originally Posted by fidia View Post
    Ill take some pics of the wheels this weekend.
    Feedrates, about 2000mm/min at max before I see PID issues but I dont believe ive tuned the new motors properly. I need a laptop with a serial connector for the software and 2 attempts to use either a USB cable or PCI to Serial connector havent worked.
    That said, 2000 is plenty for most operations. I need more spindle rpm / power now ideally as most of my stuff is Alu.
  3. Quote Originally Posted by Chaz View Post
    If you could post some pics of the mill too that would be great.
    The 10000rpm spindle on the new Tormach 440 would be really nice on the Denford. I have emailed Tormach to see if it is possible to get one as I would like to fit to my Triac.
  4. #204
    Chaz's Avatar
    Quote Originally Posted by uli12us View Post
    Can you post some pics of the ATC parts. I have a (I think) similiar machine with Pickup ATC and know what you need for this part. IIRC aou want to buy 110V solenoids for the pneumatic harness. I would better use only 24V, you can them
    connect directly to the PLC output (if the amperage of the Output is enough)
    Sorry, are you looking for info or advising me?
    I can post pics on the weekend, anything specific you need? There is also a drawing on the Denford main forum that shows how the bits fit together.
    Some here:-
    http://www.denfordata.com/pdfs/triac..._600dpi_hq.pdf
    and
    http://www.denfordata.com/bb/viewforum.php?f=47
  5. #205
    Chaz's Avatar
    Some pics below. A bit rushed this weekend, let me know if you want pics of anything specific.
    any update on your build did you finish the atc conversion?
  7. #207
    Chaz's Avatar
    Quote Originally Posted by xiteamxi View Post
    Yes, its fully working with Mach3. Id like to redo some of the wiring but its working as needed. Ive since installed an AC Servo spindle as the DC motor wasnt working well.
  8. #208
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Has been a member for 9-10 years. Has a total post count of 2,147. Received thanks 236 times, giving thanks to others 5 times.
    Any details on the servo conversion?
    I've currently got mine in bits, and am currently working on the finer details of how the servo is going to fit.
  9. #209
    Chaz's Avatar
    Ye, Ill share some stuff when I get home. I had to do a fair bit of test fitting due to the constraints of the physical space. I am using a 1.5KW Panasonic servo.
  10. #210
    So you have upgraded the spindle to a Panasonic one? How does it work with atc?
    I'm gagging to upgrade my spindle, I've got money just no options
  1. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 12:39 PM
  2. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 02:59 PM
  3. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 04:34 PM
  4. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 01:44 PM
  5. WANTED: Denford Triac
    By edwardsjc in forum Items Wanted
    Last Post: 20-08-2012, 07:17 AM
