    It has been for a few years in my thoughts, and is finally coming a reality ! I migrated from cmc-zone to here because I heard you guys like steel builds :)
    I am planning on making a steel build. I join to this post the Sketchup model, hoping that you can give me your thoughts on it and help me improve the design before I start buying parts and building.
    So far, I am thinking:
    - 12x12cm beams on the side
    - 10x20cm gantry beam
    - SBR20UU on X,Y,Z
    - rack and pinion on X,Y
    - leadscrew on Z
    - 2.2kw chinese water cooled spindle with VFD
    I already own (from a previously failed MDF build based on buildyourcnc.com's tutorials):
    - 3 x Nema 23 425oz
    - 3 x Stepper Drivers CW230
    - Power Supply 36V 9.7A
    - 6 x limit switches
    - 5 Axis Controller with parallel port
    - PC with parallel port
    - Mach 3
    - E-STOP
    - Bunch of electrical cable
    I am looking forward for your advice !
    Cheers,
    Eurikain.
    PS: I can't weld, but I have access to a welder shop that will do the work for me. I could learn, though :)
    Attached Files Attached Files
    you only need 3 limit switches :D
    Quote Originally Posted by Blackrat View Post
    You need two limit switches per axis, one for each end of the axis.
    or you can put the switch on the moving part and have two stops ;-)
    Hmm, right, but they are one direction switches, so such a placement would require a mechanism for translating bi-directional pressure to one directional.
  1. Build log. Design advice needed.
    By eurikain in forum Gantry/Router Machines & Building
    Last Post: 25-06-2015, 05:53 PM
  2. New Machine Design Advice
    By cncJim in forum Gantry/Router Machines & Building
    Last Post: 02-09-2014, 05:40 PM
  3. Design Help Pt2 Required for CNC design/Build
    Last Post: 21-07-2014, 01:05 PM
  4. Design help etc required with DIY CNC Router Design / Build
    Last Post: 21-10-2011, 03:50 PM
  5. CNC Design and advice
    By Mad Professor in forum Gantry/Router Machines & Building
    Last Post: 20-09-2010, 02:25 PM
