28-11-2015 #1
I have a DIY 4x4 CNC, which I want to adapt for plasma cutting between 3-6mm mild steel plate.
I made a torch handle holder which slots into the router clasp. My question is why do I need a floating head or THC if the sheet steel is an equal distance from the nozzle tip once zeroed?
28-11-2015 #2
28-11-2015 #3
Thanks, that's what I thought. I can see why a floating head would be useful to protect the tip. My Thermal Dynamics certainly prefers cutting on or within a 1mm of the material.
28-11-2015 #4
Yes it's good for increasing consumable life and keeping nice constant cuts etc but Good THC control is also not easy with more to it that than meets the eye.?
If the THC control doesn't factor in for cornering when machine slows down then it's easy to bury the torch into the material because has you decellerate the amperage stays the same so melts away more material and the THC control will sense this and dive to maintain the height burying the tip.
THC control is good but only if done correctly and uses good THC control.
Plasma floating head...
By Davek0974 in forum Plasma Table MachinesReplies: 27Last Post: 01-01-2015, 01:52 PM -
ballnut housing and floating end ballscrew assembly
By dsc in forum Lead Screws, Nuts & SupportsReplies: 12Last Post: 12-07-2013, 08:22 AM -
non-locating / floating bearing - shaft location
By dsc in forum Linear & Rotary MotionReplies: 5Last Post: 28-06-2013, 10:07 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM
