    looking at replacing my sem servo motor with something like this
    http://www.ebay.co.uk/itm/3KW-WATER-...item2a52124388
    as my machine has an ATC I need to get a pulley attached to the end of the spindle.
    the plan would be to mod and existing pulley rather than make a new one, so question is where do I find thread details of an ER20?
    many thanks
    Quote Originally Posted by andy_con View Post
    many thanks
    Is this what you are looking for http://www.amazon.com/Dorian-Tool-ER.../dp/B00CB0Y7SI M25 x 1.5 Thread ..Clive
    perfect many thanks
  5. #4
    Andy Are you sure the spindle you linked to will do the job as they don't have any torque at low speeds say lower than about 3.5K rpm not like a servo ..Clive
  6. #5
    well...
    I have a denford triac, its got a sem MT30U4 servo motor -
    http://igor.chudov.com/projects/Brid...ata_Manual.pdf
    although a very good motor with lots of torque it only does 4000rpm, so my feed rates are really slow. but yes I can do a 2mm deep cut in ally with an 8mm cutter, or a 1mm deep cut in ally with a 20mm cutter without any trouble.
    what I was thinking was to get one of these Chinese spindles, swap the bearings out on my mill so they can handle the speed and do a 2:1 reduction. so id be looking at 12000rpm. so I would gain a bit more torque.
    I don't actually need to run the spindle at slow speeds, I use threadmills for tapping etc...
  7. #6
    Ok I was wondering if you needed position control on the spindle for the atc. That's not so easy on the spindle you linked too.. ..Clive
  8. #7
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 2 Days Ago Has been a member for 9-10 years. Has a total post count of 1,605. Received thanks 110 times, giving thanks to others 69 times.
    many thanks
    Hi, also looking at doing this. Any success?
  9. #8
    to little info on the Chinese spindles so ive not done it
  10. #9
    Chaz's Avatar
    I might give it a try, will confirm if and when I do.
  11. The Following User Says Thank You to Chaz For This Useful Post:
  1. Denford Triac VMC
    By fidia in forum Milling Machines, Builds & Conversions
    Last Post: 19-08-2016, 08:18 AM
  2. FOR SALE: ER20 DIY Spindle Parts
    By Mad Professor in forum Items For Sale
    Last Post: 03-11-2012, 06:51 PM
  3. Conversion of ER16 spindle to ER20
    Last Post: 14-07-2012, 05:19 PM
  4. Chinese vfd/spindle question
    By Shinobiwan in forum Tool & Tooling Technology
    Last Post: 02-03-2012, 02:02 AM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
