Thread: My Cnc build
    Here we go. It all started with an idea of approx 2ft x 3 ft bed and i had a nice space in my shed to put it. I watched ebay and bought a few bits and pieces and then it went all wrong in a good way
    My brothers factory was closing down and all the square tubing was FREE. and i also got two lengths of linear rail for cheap approx 2mtrs long followed by another two lengths off the same-ish length. so i had to build one to those dimensions...Honest
    The motors and gear i had was no good for that particular size so off to Zappautomation and i bought the full set of closed loop stepper motors including THC.
    Hopefully the following pictures will tell a thousand words and you also get deducted points for a tidy workshop, so i will not be expecting any deductions .
    Cheers Tommy.
    Should there be some photos attached Tommy? Or are they on the way
    Hello
    Hopefully tomorrow night as i now know thread is live and i will have to do some reading into image sizes etc.
    Cheers Tommy
    Here we go...some materials sort from all corners of my contacts...pictures may come in various times...some before others could be completed so this will hopefully sort out the confusion..
ID:	15743   Click image for larger version.
ID:	15744   Click image for larger version.
ID:	15745   Click image for larger version.
ID:	15746   Click image for larger version.
ID:	15747   Click image for larger version.
ID:	15748   Click image for larger version.
    They were then cut, bent, welded and painted...to suit my memory plan
ID:	15754   Click image for larger version.
ID:	15755   Click image for larger version.
ID:	15756   Click image for larger version.
ID:	15757   Click image for larger version.
ID:	15758   Click image for larger version.
    Some more...
ID:	15760   Click image for larger version.
ID:	15761   Click image for larger version.
ID:	15762   Click image for larger version.
ID:	15763   Click image for larger version.
ID:	15764   Click image for larger version.
ID:	15765   Click image for larger version.
ID:	15766   Click image for larger version.
    They are on there way.just waited for my submission to be approved and need to do some reading about sizes etc...work tomorrow , so hopefully tomorrow night...
    Cheers Tommy
    Just replied and my name comes up fatty...must of joined with that name and not Skiprat...need to sort that out aswell...
    Hopefully tomorrow night as i now have had the thread approved if you know what i mean....and i need to sort out sizes of images etc...cheers Tommy
    Ive cut the square tube and it needs drilling and painting but away at the moment and not back till sunday so probablies next week for an update.....once y axispart i should be able to make somw makeshift reduction parts to allow the machine to cut out its own "permanent" ones.
    Cheers Tommy
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. BUILD LOG: New Build - For Your Amusement - MK-2 build
