    Hi All
    I want to make a router, a large router. I make kitchens, bedrooms etc. I use jumbo boards of MFC (2070mm x 2800mm), and sometimes long MDF sheets (1220mm x 3050mm). I would like to use it to cut nested panels, putting full sheets on and walking away to edge / further fettle what has been cut from the previous board. I would like to be using it at times for dovetailing and other jointing,needing to put pieces vertically at times, but i don't think it will make a huge difference to the main design as that will happen at the end of the table.
    I'm probably going to have forgotten loads of thoughts of the design, but i just want to start the design consultation with the forum. I have therefore produced an initial design in sketchup. I thought that starting with the main frame design, and then moving on from there after getting that sorted.
    Working area of 2100mm x 3050mm.
    Steeel frame design, main rails 100x200, legs etc 100x100. Overkill?
    Using resin or shims for rails? I was thinking resin, but then recently read conflicting thoughts.
    Linear guide rails.
    Rotating nut ballscrew on the x axis. Normal ballscrew on Y and Z.
    Twin head design running one with a 1/2" cutter (for doing the main cutting), and one with 5mm (a common hole size i need). I don't want to be changing cutters manually mid sheet, and a tool changer is a step too far for me i think.
    Attachment 17521
    As i said, the design is in it's very early stages, I'd like to get it right from the ground up so will take it one step at a time. At this point i'm interested to hear peoples views on the idea as a whole, as well as the main frame design.
    Thanks in advance.
    Nathan
    sth is wrong with the pictures?
Name:	3050 x 2010 design 01a.jpg
ID:	17537Click image for larger version.
Name:	3050 x 2010 design 01b_1_1.jpg
ID:	17538Click image for larger version.
Name:	3050 x 2010 design 01c.jpg
    Dual rotating nut ballscrew on x.
    Nathan
  1. Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
    By Wejjmeister in forum Gantry/Router Machines & Building
    Last Post: 03-01-2016, 12:45 AM
  2. BUILD LOG: First CNC Project - 3 Axis - Large table format
    By Xavi in forum DIY Router Build Logs
    Last Post: 01-12-2015, 10:44 PM
  3. BUILD LOG: Steel Framed CNC router
    By Joe in forum DIY Router Build Logs
    Last Post: 23-06-2013, 10:45 PM
  4. BUILD LOG: Steel Framed Router
    Last Post: 14-09-2011, 06:51 PM
  5. BUILD LOG: My steel framed router
    By pavlo in forum DIY Router Build Logs
    Last Post: 06-03-2011, 10:08 PM
