    Hi, first post in a while since getting my desktop cnc lathe and its bigger brother operational.
    I have decided to create some small wooden knife handles and am currently
    currently limited to round parts. These are fun but I want something oval and 3d
    carved.
    I don't have a 4 axis CNC router and my mill is ages away from CNC
    completion. What I do have is a small CNC lathe that I want to alter to
    have a stepper controlled chuck (C Axis I believe) and a router fixed on the
    X axis. From want I have seen online, a lot of 4 axis CNC Routers just
    follow the centre line of a rotational part and 3D carve it (Effectively 3
    Axis as the 4th doesn't get used).
    Could this principle be applied to my lathe as it will effectively have 3
    axis control? I can't see the difference but I am probably missing
    something vital.
    Thanks,
    Chris
    Hi Sooty
    Have a look @ this http://www.practicalmachinist.com/vb...elipse-186593/
    There are some pointers regarding code for the lathe,
    Regards
    Mike
    Thanks for the info I will have a read.
    I have an additional question, should I use a larder belt drive pulley on the chuck than the stepper. I figure if the stepper has a smaller pulley I will get better resolution? or does this not matter?
    thanks!
  1. Problem with Mach 3 converted lathe x axis Boxford TCL 160
    By FarrerDesign in forum Boxford Lathes
    Last Post: 07-08-2013, 08:37 PM
  2. BUILD LOG: 3 Axis Router
    Last Post: 22-01-2013, 12:08 PM
  3. FOR SALE: router lathe
    By johngoodrich in forum Items For Sale
    Last Post: 09-11-2012, 09:37 PM
  4. 4th Axis running as CNC lathe using milling machine
    By Jonathan in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2011, 09:34 AM
  5. Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
    By No1_sonuk in forum Lead Screws, Nuts & Supports
    Last Post: 17-05-2010, 11:47 AM
