18-08-2015 #1
Hi !
This is a story about an all steel, 2000 x 1300 x 250 mm work area CNC router, where nuts and bolts replace weldments.
The idea is quite simple and the concept is not new and has been tested and verified to work on a small steel design. I decided to scale it up to 10mm steel sheets.
But my goal was not only to remove the need of welding, but also to integrate a linear shaft support so that round supported rails can be made cheaper. Almost all parts will be plasma cut from 10mm steel sheets. A few parts, like the Z axis moving plate and the ball nut attachment plates will be cut from 15mm steel sheets to reduce binding or avoid bracing. Linear rails are standard 20mm stainless steel shafts. and will be welded to the supports (I haven't found a way to fix them using nuts and bolts that would fit with my design, and I don't believe it would be a good way to do it).
Here are a few renders of the complete Z axis design (calculated weight is 9kg without spindle):
Complete Z axis.
Inside the frame.
This image shows the steel bolt and nut connection, plus the integrated linear shaft support. You can also see how the connections affect the part by cutting the shape of the bolt and nut, and adding joints on both sides of the bolt. I actually made smart components that achieve this. I have a few different versions and sizes for the connections:
- simple: cuts the shape of the bolt and nut
- single: cuts the shape of the bolt and nut + a "tooth" on one side (sizes are small, medium or large)
- double: cuts the shape of the bolt and nut + a "tooth" on both sides (sizes are small, medium or large)
All cuts have a play of .1mm. Bolts are M10 x 35mm with matching nut (standard, grade or pitch don't really matter as there aren't any tapped holes).
Back of the Z moving plate with balll nut support. All made from 15mm steel sheet.
Machine specification:
Workarea:
X: 2000mm
Y: 1300mm
Z: 250mm
Weight:
X: ?
Y: 28kg without gantry sides and without Z
Z: 9kg without spindle
Linear motion:
X: SBR20UU + SFU2010 2000mm
Y: SBR20UU + SFU1610 1300mm
Z: SBR20UU + SFU1605 500mm (because it came with supports and couplers, and was cheaper than shorter lengths)
Linear motion electronics:
X: 2 x Nema 23 425oz/in driven by 2 x Leadshine AM882
Y: 1 x Nema 23 450oz/in driven by Leadshine AM882
Z: 1 x Nema 23 425oz/in driven by Leadshine AM882
Spindle:
2.2kw water cooled + VFD
Breakout board:
Basic 5 axis board, 4 limit switches, with Mach3 support, from BuildYourCNC.
Power supply:
DIY unregulated 70V 10A, following Boyan and Clive advices.
Where I got the parts:
- Ballscrews + nuts + end supports + couplers are from AliExpress seller Kevin Ho at ROB BEARING AND MECHANICAL PARTS. Contact him if you need custom lengths (that's what I did).
- Nema 23 425oz/in + breakout board are from buildyourcnc.com 3 axis Nema 23 electronics kit (I purchased them 4 years ago).
- Nema 23 450oz/in is from a random seller on AliExpress.
- spindle kit is originally from another AliExpress seller but I found the shipping price too high, so I asked Kevin Ho (the guy from whom I bought the ballscrews) if he could get the kit for me with a better price and he gave me a $60 discount (this is calculated using kit price on August 18th of 2015, which is the day I am writing these lines).
- AM882 drives are from here. Be careful to make orders with maximum THREE drives or you'll pay for shipping. I did an order of three and another of one.
- SBR blocks are from here. Again, be careful to make orders of maximum TWO packs, or you'll pay for shipping. I did an order of two and another of one.
Currently shipping:
- spindle kit
- 3 nema 23 couplers (made a mistake by ordering 8mm couplers instead of 6.35, so had to re-order).
Modelling on:
Solidworks 2014 SP2
Windows 7 Home Basic
Eight year old HP Pavilion DV6500, 2GB RAM, small NVIDIA graphics chipset
Your input is welcome and very valuable to me ! I will make the DXF files when done modeling the entire machine, and when most of you will agree with the general design. Plus, there's no hurry to get the parts, as the company I work with will have them cut in the next 24 hours after they receive the files.
Special thanks to Boyan Silyavski, Clive S, toomast, all members that have answered my questions, and all members that contribute to this amazing forum.
I will start the design of the gantry tomorrow. I am too tired of clicking the Solidworks "rebuild" button for today.
Cheers,
Eurikain.Last edited by eurikain; 20-08-2015 at 01:36 PM.
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
Welding bench
By Boyan Silyavski in forum Metalwork Project ShowcaseReplies: 4Last Post: 12-07-2015, 05:01 PM -
RFQ: RFQ TIG welding
By Robin Hewitt in forum Projects, Jobs & RequestsReplies: 9Last Post: 01-02-2013, 10:41 PM -
Welding Consumables
By GTJim in forum Welding, Brazing & EquipmentReplies: 5Last Post: 13-12-2012, 01:33 PM -
TIG welding
By Robin Hewitt in forum Welding, Brazing & EquipmentReplies: 2Last Post: 03-04-2012, 10:38 PM
