Thread: Turnkey solution
	24-08-2015 #1
Hi There, first time posting on here so please be gentle.
Firstly I know almost nothing about CNC machines and almost definitely haven't got time to learn enough to build my own machine like most of you good folk seem to have done. I am a woodworker who builds quite a few bespoke speaker cabinets for customers amongst other things. I'd like to transfer most of the panel machining over to CNC as it seems that this would drastically reduce the time it takes to produce repeatable accuracy parts.
My first thoughts were that I should get a machine that took a full 8' x 4' sheet of material but in this country that seems prohibitively expensive. My budget is £5k max really.
There seems to be a plethora of machines on E-bay but none really seem big enough, I reckon I could get away with cutting 1/4 boards so 1220 x 660 working area. I came a across a few companies that could supply either all the electronics or some of the frame, but very few that could supply a turnkey solution.
CNC4you quoted me
1 RM1605-C7 Ballscrew -600mm £70.40 £70.40
2 RM1605-C7 Ballscrew -1200mm £86.40 £172.80
3 BK12 ballscrew support TMT £47.96 £143.88
3 BF12 ballscrew support TMT £24.86 £74.58
3 Ballscrew mount ID28mm £7.10 £21.30
2 HGR20 square rail -1400mm £77.30 £154.60
2 HGR20 square rail -700mm £43.30 £86.60
8 Hiwin20 square carriage £28.86 £230.88
1 4Nm digital stepper motor kit x 4 Axis with mounts £435.92 £435.92
4 8MM-10MM XB coupling (large) £11.45 £45.80
1 Z Axis 300mm ballscrew with plain mount £275.36 £275.36
1 2.2Kw spindle + VFD + mount kit £387.78 £387.78
1 Water pump £41.99 £41.99
10 water pump tubing £1.76 £17.60
1 External E-stop £12.43 £12.43
10 4 Core screened cable 0.5mm £2.08 £20.80
4 4 Core screened cable 0.75mm £2.49 £9.96
1 Mach3 cnc control software £95.04 £95.04
1 UC300 motion controller £104.99 £104.99
Subtotal £2402.71
UK Mainland shipping £13.38
V.A.T 20% £483.22
Total £2899.31
which seems reasonable but I have no idea where to start speccing the rest of the stuff I'd need to build it or even what I'd need TBH. I asked them if they could spec a turnkey machine but never got a reply - busy I guess.
I also came across this machine on world of CNC http://www.worldofcnc.com/collection...router-package which seems almost perfect for what I need although there is very little detail on the specs. I like that there is support and installation included. However when I looked into the company there are MANY complaints here about the business practices and actually getting a machine, this does seem at odds with their exemplary ebay star rating however.
I also like the look of this http://www.prototools.co.uk/shop/cus...cat=522&page=1 but again thin on specs, they do a more heavy duty version http://www.prototools.co.uk/shop/cus...99&cat=0&page= that looks more in line with the hardware quote I got from CNC4you but it is much more expensive at nearly £8.5k inc VAT.
So far the world of CNC one seems like the best bet, and I like the idea of hand holding etc but not if they are con men.
Any help or advice would be very much appreciated.
Stefan
	31-08-2015 #2
Had a couple of nice conversations with members about this. But big thanks to Jazz who wrote me a long emal, we still need to talk but he was very helpful. Also Petesos who let me come look a t his machine that he bought from a source I am considering. He was very helpful and let me have a fiddle about for a couple of hours. Thanks Pete.
Stefan
	01-09-2015 #3
Hi Stefan
Welcome to the forum.
Good luck with your purchase.
Very nice to see that Dean is still watching and helping out. @ least his e mails can't get deleted.
Kindest regards
Mike
The Following User Says Thank You to mekanik For This Useful Post:
	01-09-2015 #4
cheap dust collection solution?
By MikeyC38 in forum Machine DiscussionReplies: 5Last Post: 01-12-2012, 05:22 PM -
Hold down solution
By jonbabbz in forum General DiscussionReplies: 4Last Post: 11-10-2012, 08:21 PM -
how can I find a precision solution partner?
By sysupplier in forum Manufacturer NewsReplies: 0Last Post: 01-09-2012, 10:19 AM -
Nut solution made easy
By Swarfing in forum Machine DiscussionReplies: 0Last Post: 08-02-2011, 10:52 PM -
wonderfull linear solution ????????
By cncroutman in forum Linear & Rotary MotionReplies: 0Last Post: 26-07-2010, 12:42 PM
