    Hello all!
    I haven't posted on here for a good while as I've been a very busy boy (not machine building unfortunately) but at the weekend I decided to get on with it and get my machine actually moving.
    I did post on here about 18months ago with regards to my build and I got some very helpful advice from several members (jazzcnc in particular) when it came to getting the electronics right. I purchased the leadshine MX3660 unit to drive my steppers which is a very nice bit of kit especially for a newbie machine builder like me.
    I'm using linuxcnc. All seems to working well except the z axis. The x and y work fine which is why I'm confused as to why the z axis is not moving. All the steppers are wired up the same (parallel) and the lead screws the same on all 3 axes (4mm pitch trapezoidal). The only difference is the z is using a pulley and belt while the x and y are directly coupled.
    The x and y move fine in all directions when holding down the jog key, whereas the z just stalls. If I keep pressing the jog key the stepper moves tiny amounts at a time but it won't feed or jog at all.
    I'm kind of lost as to what I have done wrong as each axis has been setup exactly the same in both the Linux software and on the leadshine unit jumpers. Or am I missing something simple?
    I have uploaded a video on YouTube to make it a bit easier to explain.
    http://youtu.be/HdqXq71MUcE
    Please excuse the very poor narration lol.
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,334. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Have you tried swapping the z over to the x or y just to test. Post the ini and hal file .. ..Clive
    I hope you get this going right Thomas it looks to be a lot of fun.
    You mention Jazz I sure wish he was still on the forum, in my view the forum has lost a great guy and it just isn't the same without him. He was a great help to me nice to talk to.
    All the best
    Suesi
    Hi there thanks for the reply.
    I have just tried swapping the z stepper cables with the y and the z axis moved fine, the y then had the problem. So does this tell me that the wiring is fine but there must be something wrong with the mx3660 unit?
    I hope that's not the case! As I bought this over a year ago which means my warranty will have run out! Even though it is basically brand new.
    Quote Originally Posted by thomashomer1986 View Post
    Can you post the .ini and hal files and a picture of the settings on the drive like I suggested before.
    Apologies for missing your previous question.
    i cannot upload the .hal and .ini files, so I'm presuming you just mean copy and paste the content?
    the .hal file:
    # Generated by stepconf at Mon Aug 24 20:58:12 2015
    # If you make changes to this file, they will be
    # overwritten when you run stepconf again
    loadrt trivkins
    loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
    loadrt probe_parport
    loadrt hal_parport cfg="0x378 out "
    loadrt stepgen step_type=0,0,0
    addf parport.0.read base-thread
    addf stepgen.make-pulses base-thread
    addf parport.0.write base-thread
    addf stepgen.capture-position servo-thread
    addf motion-command-handler servo-thread
    addf motion-controller servo-thread
    addf stepgen.update-freq servo-thread
    net spindle-cmd <= motion.spindle-speed-out
    net xstep => parport.0.pin-02-out
    net xdir => parport.0.pin-03-out
    net ystep => parport.0.pin-04-out
    setp parport.0.pin-05-out-invert 1
    net ydir => parport.0.pin-05-out
    net zstep => parport.0.pin-06-out
    net zdir => parport.0.pin-07-out
    net estop-ext <= parport.0.pin-15-in-not
    setp stepgen.0.position-scale [AXIS_0]SCALE
    setp stepgen.0.steplen 1
    setp stepgen.0.stepspace 1
    setp stepgen.0.dirhold 210769
    setp stepgen.0.dirsetup 210769
    setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
    net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
    net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
    net xstep <= stepgen.0.step
    net xdir <= stepgen.0.dir
    net xenable axis.0.amp-enable-out => stepgen.0.enable
    setp stepgen.1.position-scale [AXIS_1]SCALE
    setp stepgen.1.steplen 1
    setp stepgen.1.stepspace 1
    setp stepgen.1.dirhold 210769
    setp stepgen.1.dirsetup 210769
    setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
    net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
    net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
    net ystep <= stepgen.1.step
    net ydir <= stepgen.1.dir
    net yenable axis.1.amp-enable-out => stepgen.1.enable
    setp stepgen.2.position-scale [AXIS_2]SCALE
    setp stepgen.2.steplen 1
    setp stepgen.2.stepspace 1
    setp stepgen.2.dirhold 210769
    setp stepgen.2.dirsetup 210769
    setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
    net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
    net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
    net zstep <= stepgen.2.step
    net zdir <= stepgen.2.dir
    net zenable axis.2.amp-enable-out => stepgen.2.enable
    net estop-out <= iocontrol.0.user-enable-out
    net estop-ext => iocontrol.0.emc-enable-in
    loadusr -W hal_manualtoolchange
    net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
    net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
    net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
    net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
    the .ini file:
    [EMC]
    MACHINE = Linux-CNC-Router
    DEBUG = 0
    [DISPLAY]
    DISPLAY = axis
    EDITOR = gedit
    POSITION_OFFSET = RELATIVE
    POSITION_FEEDBACK = ACTUAL
    MAX_FEED_OVERRIDE = 1.2
    INTRO_TIME = 5
    PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
    INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
    [FILTER]
    PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image
    PROGRAM_EXTENSION = .py Python Script
    png = image-to-gcode
    gif = image-to-gcode
    jpg = image-to-gcode
    py = python
    [TASK]
    TASK = milltask
    CYCLE_TIME = 0.010
    [RS274NGC]
    PARAMETER_FILE = linuxcnc.var
    [EMCMOT]
    EMCMOT = motmod
    COMM_TIMEOUT = 1.0
    COMM_WAIT = 0.010
    BASE_PERIOD = 20769
    SERVO_PERIOD = 1000000
    [HAL]
    HALFILE = Linux-CNC-Router.hal
    HALFILE = custom.hal
    POSTGUI_HALFILE = custom_postgui.hal
    [TRAJ]
    AXES = 3
    COORDINATES = X Y Z
    LINEAR_UNITS = mm
    ANGULAR_UNITS = degree
    CYCLE_TIME = 0.010
    DEFAULT_VELOCITY = 5.00
    MAX_LINEAR_VELOCITY = 50.00
    [EMCIO]
    EMCIO = io
    CYCLE_TIME = 0.100
    TOOL_TABLE = tool.tbl
    [AXIS_0]
    TYPE = LINEAR
    HOME = 0.0
    MAX_VELOCITY = 28.5882806105
    MAX_ACCELERATION = 50.0
    STEPGEN_MAXACCEL = 62.5
    SCALE = 800.0
    FERROR = 1
    MIN_FERROR = .25
    MIN_LIMIT = -0.001
    MAX_LIMIT = 250.0
    HOME_OFFSET = 0.0
    [AXIS_1]
    TYPE = LINEAR
    HOME = 0.0
    SCALE = 800.0
    FERROR = 1
    MIN_FERROR = .25
    MIN_LIMIT = -0.001
    MAX_LIMIT = 250.0
    HOME_OFFSET = 0.0
    [AXIS_2]
    TYPE = LINEAR
    HOME = 0.0
    MAX_VELOCITY = 25.0
    MAX_ACCELERATION = 25.0
    STEPGEN_MAXACCEL = 31.25
    SCALE = 800.0
    FERROR = 1
    MIN_FERROR = .25
    MIN_LIMIT = -0.001
    MAX_LIMIT = 0.001
    HOME_OFFSET = 0.0
    One thing I have just noticed is that when im in the step config wizard and i click on the 'test this axis' button. my z axis moves fine?
    Ok Just had a quick look see this:-
    TYPE = LINEAR
    HOME = 0.0
    MAX_VELOCITY = 25.0
    MAX_ACCELERATION = 25.0 this should be a lot higher
    SCALE = 800.0
    FERROR = 1
    MIN_FERROR = .25
    MIN_LIMIT = -0.001
    MAX_LIMIT = 0.001
    HOME_OFFSET = 0.0
    so the most it can move is .002mm So alter the Min limit and try again say -100 or what ever your Z is
    Will add forum support for those file types shortly Clive...
    .Me
    .Me
    .Me
    They are just text files they just need the extension changing to .txt but it would good to allow .ini and .hal
    Clive you are my hero!
    It now works. I changed the z axis limits to be between -75 and 0. I was sure that I had tried it at that setting before but i must have got the numbers the wrong way round.
    Thank you very much for your help. All I need to do now is buy a spindle and wire up the limit switches and it'll be ready for production work lol.
  1. WANTED: TB6560 + PSU, Drivers, BOB's, Nema 23 Kits DEAD or ALIVE
    By longy in forum Items Wanted
    Last Post: 16-06-2014, 04:15 PM
  2. It`s alive
    By gorbo in forum General Discussion
    Last Post: 16-11-2010, 08:09 PM
