26-08-2015 #9
If i was doing the job i would also use a jig but slightly different, would make it with 2 holes with an L shape cross section, make all holes on the assembly the same pitch, so you would clamp the jig drill & tap first hole, shouldered bolt goes in that hole, do second hole, move jig down using the shouldered bolt in the second hole drill & tap third hole in so on, the jig can also be used on the clear holes.
Mike
FOR SALE: Batch of 3 6082/T6 Aluminium Plates
By Solihull1 in forum Items For SaleReplies: 3Last Post: 26-02-2015, 10:04 PM -
SOLD: Aluminium plates/blocks with sawn edges and the odd minor surface scratch
By Solihull1 in forum Items For SaleReplies: 0Last Post: 06-12-2014, 11:12 AM -
RFQ: Small turned part. Cross drilled. quotes or advice please.
By jimbo_cnc in forum Projects, Jobs & RequestsReplies: 0Last Post: 23-06-2014, 08:41 PM -
RFQ: RFQ: 3 x M5 holes drilled and tapped/ +/- 0.01mm required
By neurofen in forum Projects, Jobs & RequestsReplies: 9Last Post: 25-01-2012, 04:26 PM -
Now if only someone invented a drill that drilled square holes.....
By HankMcSpank in forum General DiscussionReplies: 3Last Post: 20-10-2011, 10:07 PM
