    I've been milling MDF, but I noticed my cutter (5mm dia HSS 3 flute up cut) was a tiny bit black at the bottom, and after last time it's SERIOUSLY blackened, I assume this means its damaged, and I've not routed fast enough.
    The profile cut settings were 2.5mm pass depth (9mm depth material), 15000 RPM, feed 3900 mm/min, should I step that feed up to 4000+?
    Any advice would be brilliant. I'm not sure whether to use the cutter again or not too, it's still sharp to touch, it just looks like the bottom 3-4mm of it has spent the night in a chimney!
    Cheers, Mark.
    Quote Originally Posted by mark84 View Post
    Cheers, Mark.
    I would use the cutter and up the federate if the machine can take it.
  3. The Following User Says Thank You to Clive S For This Useful Post:
  1. Need help building a cnc-cutter
    By Arctic monkey in forum Gantry/Router Machines & Building
    Last Post: 03-12-2014, 07:23 PM
  2. Laser cutter
    By John S in forum Laser Machines & Building
    Last Post: 02-06-2012, 01:16 PM
  3. cutter for MDF
    By deannos in forum Tool & Tooling Technology
    Last Post: 16-10-2011, 08:33 PM
  4. cutter chipload
    By johngoodrich in forum Tool & Tooling Technology
    Last Post: 17-09-2011, 12:02 PM
  5. First Plasma Cutter
    By antsals in forum Plasma Table Machines
    Last Post: 16-05-2011, 06:58 AM
