Hi all
I've just joined this forum after doing a goggle search for forums. Here's a quick synopsis: I'm a cnc miller by trade, and have worked on mainly Fanuc and Heidenhain controls. I would like a single phase cnc milling machine for my home so I can make RC car and helicopter parts as I like doing stuff like that. These will be primarily from ali I wish to add.
I have no idea what machines are out there. So far I have discovered the Syil X series, Contour Minor and Denford Triac and the odd one or two others by searching the internerd, but that's as far as I have got as far as market knowledge goes. I'm of the understanding that these machines run on a program called Mach 3, and I have been pointed in the direction of another program called Fusion 360, which I am yet to download. I've just inherited an old PC with which to run operating software on, and....... That's as much as I know, and now you know the task and learning curve ahead of me.
I'd prefer to buy 2nd hand at this time as I don't have the dosh to buy new, So I would like to know if you guys have any recommendations as to machines, programs, pros and cons of each and so on and so forth.
Many thanks in advanceRC cars
RC helicopters
Motorbikes
Renovating an entire house
Twatter: @CrazyLThirteen
Insta: CrazyLThirteen
07-09-2015 #2
Well, Nothing says being helpful like 85 views and no replies. I had better start doing my own research then.
RC cars
RC helicopters
Motorbikes
07-09-2015 #3
Well I dont visit here very often but I'll throw in my tuppence worth. Mach 3 is one of the programs available for machine control. Personally I use Eding cnc which I prefer but its up to you.
Fusion 360 from Autocad looks like a very good program. I have it myself but havent had time to get into it. Its available for free as a hobbyist license.
07-09-2015 #4
Well I did see this and think to try posting and seen has you haven't had any replys I'll give this a Go but probably won't get thru the censors.!
Ok well here goes.!
Have you thought about building your own.? . . . With Your needs of wanting to cut mostly Ali and small parts for RC cars etc then you'll probably be better served with small strong Fixed gantry router type machine with high speed spindle that's more suited to Ali.
Most small mills don't have enough spindle speed/power to cut ali at feed rates for best finish etc. Building a small Fixed gantry machine isn't difficult, esp if your into engineering and tooled up.
You'll end up with a much better machine custom suited to your needs. And it will cost much less than buying a Mill and converting.
I know you haven't had much response here so far but if you did take the Self build route then others would start chip in with advise thats for sure. If not then contact me directly and I'll glady tell you everything you need know from A to Z. Which your quite welcome to do now if you don't want to DIY build.!
WELL Bugger me senseless it got thru.!! . .Last edited by JAZZCNC; 07-09-2015 at 05:06 PM.
Here is a very nice little fixed gantry machine built by Wal http://www.mycncuk.com/threads/7001-...t=fixed+gantry post 9
I have seen the intricate work he has done on this I think there are some pics on here somewhere. ..Clive..Clive
07-09-2015 #6
Hi Crazy L
I also read your post but I have only heard about the Syil and Denford machines but not used them myself.
Mach3 software is a machine control program to read Gcode files (created by a CAM program) and turn them into machine movement. In basic form it sends the signals out of the parallel port to a Break Out Board (BOB), which in turn controls stepper motor drivers, which then turn the stepper motors, which turn the leadscrews and move the spindle (or workpiece).
I think most people on here have built their own from scratch, with the odd conversion, which is also why you didn't get a response.
Also, the new member, JazzCNC, should introduce himself . . .
07-09-2015 #7
10-09-2015 #8
Thanks for chipping in. I see these routers all over ebay, cheap as dirt, so I've been put right off them. Another turn off is when I read they can only hold a 3mm tool for example. do you suggest I give them a more in depth look?
Building my own, hmmm.....I have 2 motorbikes, 3 rc helicopters, 7 rc cars, a house to do up. I'm not quite sure I have the time right now, although the prospect sounds appealing (depending what mood I'm in).
Thanks for the replies guys, I was starting to think I was on my own there for a while, like the leper kid at school. lol (we never had an actual leper at our school btw)RC cars
RC helicopters
Motorbikes
10-09-2015 #9
No I suggest you avoid them like a dose of Clap.!!! . . . Only use is for learning on which you clearly don't need.
This is exactly what I suggest you do.!! . . . . I know you'll get a better suited machine to your needs cheaper than converting a small mill that is mostly unsuitable for cutting small parts in Aluminium. If you was looking to cut steel then I'd say yes go with a small mill but not Ali and with relatively small tooling.
A nice small strong fixed Gantry machine like Wal's but with profiled linear rails and nice fast spindle like 2.2Kw ER20 will serve you much better and for fraction the price of decent mill that wil most likely have an unsuitable spindle speed range for Ali.!
If you haven't got time to build one then you probably haven't really got time to convert one because there won't be a lot in it unless you buy a ready made convertion kit.!!
. . Mechanicly if your tooled up and know how to use them. Prepare well getting all the stuff together before proceeding and settle on design with a plan of attack then you'll build one in same time has stripping, making motor plates and adaptions or mods that most mills require.
Electronics wise there exactly the same amount of work.!!
12-09-2015 #10
Denford vmc1300
http://website.denford.ltd.uk/machin...mill-and-turns
New to CNC Machines. Any advise on a low end machine?
By Millatime16 in forum Machine DiscussionReplies: 5Last Post: 05-12-2014, 07:36 PM -
Advise on building a CNC table
By T0rnado69 in forum Gantry/Router Machines & BuildingReplies: 24Last Post: 30-06-2014, 11:19 PM -
I need advise again
By habibuzziwa in forum General DiscussionReplies: 14Last Post: 08-10-2012, 10:08 AM -
I need advise
By habibuzziwa in forum General DiscussionReplies: 7Last Post: 03-10-2012, 10:50 AM -
Spindle help, please advise
By djh82uk in forum Spindles & Drive MotorsReplies: 2Last Post: 22-09-2007, 04:02 AM
