Thread: 4 axis rotary
    i dont think i got this in the right section ... please move if not
    here goes ...
    what im trying to understand on a rotary axis is how is the g code defined
    for example , ive read (or watched you tube vids) that when using for example aspire vectric , that the x axis ( for example , could also be Y ) is unplugged and the rotary axis is plugged into this axis , so really the machine becomes a y and z linear machine and x rotary (so still a 3 axis machine not 4 ? )
    but now if you had to use solidcam, camworks, etc then you could have a true 4 axis machine , so you could rough a piece of material lets say at 0 degrees, then rotate it 180 degrees and rough it again. Then do a finishing pass using the rotary axis ?
    is that the way it works ?
    A proper cam program, depending on the post processor of course, will define the 4th axis as "A". So you have X, Y, Z, & A, and of course B, C if you have 6 axes.
    Now the movement in "A" may be in mm or in degrees depending on your machine settings. There is a tick box in mach3 for that.
    https://emvioeng.com
    If you're hand coding you need to start out understanding how the G-Code works, if you have a decent CAD/CAM package you just need to get the config right and the code comes out right.
    There are so many ways to skin this cat, you can rough and finish a 4-Axis job in 3 Axes with manual 90 degree indexing, without using a 4th.
    - Nick
    As the guys said, you'll have an x,y,z and a axis. Best bet is to do all the roughing in 3 axis mode and just index 90 degrees each time, then do your finishing in 4 axis mode to optimise the surface finish. Solidcam has some nice features where you can finish parallel to a curve or to an axis or you can let your toolpath morph from the shape that defines one side of a face to that or the other. So if one end of the face was an arc and the other a straight line, your toolpath woud start as an arc and gradually change as it machines the face to straight lines. Nifty stuff.
    Noel.
  1. CNC Engraving Rotational Rotary Axis
    By Fivetide in forum Machine Discussion
    Last Post: 31-07-2015, 09:34 AM
  2. Sturdy Rotary Axis for CNC table
    By Boyan Silyavski in forum Linear & Rotary Motion
    Last Post: 31-08-2014, 10:53 AM
  3. DIY Rotary Encoders?
    By birchy in forum Electronic Project Building
    Last Post: 15-09-2013, 02:09 PM
  4. Diy 4th axis rotary table using 100mm chuck with minimal backlash
    By kingcreaky in forum Linear & Rotary Motion
    Last Post: 05-09-2013, 12:03 PM
  5. Bearings(Rotary)
    By GeorgeD in forum Linear & Rotary Motion
    Last Post: 14-08-2010, 04:50 PM
