    I have no more ideas for my problem ... PLEASE HELP !!!
    What I want to eliminate .... When I moving Y axis by JOG ... after 10 - 20 or 30 cm of movement ... and when I hold the stepper motor by hand .. I fill strange, fast, single motor stall for very small period of time . This is as losing steps ..... When add dial indicator to the axe after some movements .... I lose 0.1 mm linear accuracy ... for 1-2 and more hours will be about 5 mm .... maybe
    The sound is like a little, fast "knock" ....
    What I did to eliminate the problem, noise .. losing steps ...
    I tried many combinations
    - 2 PC with Mach3 + LPT to the drivers. ( Acer 2 GB, 3 GHz.... Win XP .. ) and Cel 2.4 GHz, 256 MB ... Win XP
    - 2 types of drivers - DQ860MA + Purelogic driver PLD8220-G2
    - 2 power supplies ...
    - 3 types of stepper motors - nema 23 - and 34 x 2...
    - long shielded cables .. and short ...ones .
    - Ground pipe in earth with cable to all shields .... cases ....
    - tried all BIOS LPT modes EPP etc ..
    - kernel mode - 25 and one level up KHz
    - LPT direct cable to driver and thru BOB PCB card ....
    With single G code - Y500 F500 .. after some mm I fill the same issue ...
    When unattached motor is on the table ... the problem is the same ...
    I have single phase 220 AC voltage ....
    If someone have any ideas ... wiring drawings - please send it ... THANK YOU !!
    Emil
  1. New machine bogging down / missing steps
    By James123 in forum Gantry/Router Machines & Building
    Last Post: 19-12-2014, 12:02 AM
  2. clunks / missing steps - DM856 and single pulse operation
    By dsc in forum Motor Drivers & Controllers
    Last Post: 09-12-2013, 02:22 PM
  3. mach3, steps & microstepping
    By martin54 in forum Artsoft Mach (3 & 4)
    Last Post: 10-04-2013, 08:00 PM
  4. Strange problem, possibly missing steps?
    By Philly in forum Chinese Machines
    Last Post: 26-10-2012, 06:36 PM
  5. Missing Steps + Stalling X-axis
    By danielbriggs in forum Linear & Rotary Motion
    Last Post: 02-09-2010, 02:59 PM
