19-09-2015 #1
Hi folks
I would like to show my design before fabrication in case you spot something not wright.
Machine itself is tiny - working area 320x320x100. Reason for that is that I am limited with my Mill.
I will not use epoxy for any leveling, base for linear rails will be machined.
My mill with 2.5" head can do pass 450mm long along longest travel.
Both base on bed will be done from one fix - that is why frame is 360mm wide excluding base for rails and rails itself.
Profiles 50x25x2.5. I had them very cheap considering UK prices for steel.
THK 15 rails with two blocks on each rails
RM1605 ballscrew on X and Y
RM1204 on Z
Nema 23 3.1Nm stepper
Belt drive HTD 5M 15T-20T - height of profile determine that, gear 30T is greater than 50mm and sticks out from bed
Spindle - Kress 1050
Design is nearly done - only home/limit switches are mising, cable carriers and few cosmetic item - brackets etc.
Any comments welcome
TomLast edited by Tom J; 19-09-2015 at 10:36 PM.
600x900 Steel welded router build
By embraced in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 08-10-2014, 10:55 PM -
5 axis desktop machine Kickstarter
By 5AXISMAKER in forum Machine DiscussionReplies: 6Last Post: 24-09-2014, 08:41 PM -
Desktop size build to learn on - PCB routing / small MDF work.
By dynamis_dk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 26-02-2014, 11:50 PM -
FOR SALE: Strong steel welded base with ground flat surface.
By black5f in forum Items For SaleReplies: 0Last Post: 14-01-2012, 07:20 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM
