Page 2 of 2 FirstFirst 12
    Quote Originally Posted by Wayne View Post
    I think my bits would be 90% aluminium. Providing I could do a bit of 3D machining (not fourth axis) and get a good surface finish, I'd be happy.
    I'd be interested in looking at the Denford - it would suit me well (not too large).
    Sorry if I'm going to sound negative but the Denford won't be good for Aluminium and 3D.! . . Why.? . . . Because of the lack of spindle speed.
    Aluminium in general needs faster spindle speeds than most mills can offer. Yes they will cut it no problem but feed rate will be slow and the surface finish not the best. This gets worse when your looking to do 3D work because often smaller Diameter tools are involved which require much higher spindle speeds.
    So if your thinking mostly aluminium work and looking at mills then bare spindle speed in mind.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #12
    Your Denford is just what I am looking for. Have you decided to sell it yet or perhaps you already have? I would be very interested if you are. Call me on 07803 895933 if you wish. Thanks, Roy
  4. #13
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 2 Hours Ago Has been a member for 5-6 years. Has a total post count of 1,110. Received thanks 78 times, giving thanks to others 51 times.
    Quote Originally Posted by Whurlyburd View Post
    Me? You should quote, we get alerted and then I know who you are referring to.
    Still using mine but if you are interested, make an offer.
  5. #14
    Hi Chaz,
    Id be interested in buying the mill, how could I get in touch?
    Chris
  6. #15
    Chaz's Avatar
    Quote Originally Posted by Crichards View Post
    Hi Chaz,
    Chris
    Ill pm you my email address.
  1. BUILD LOG: Steel Gantry Machine 1500x750x200
    By toomast in forum DIY Router Build Logs
    Last Post: 02-03-2018, 05:27 PM
  2. polishing stainless steel machine
    By Blackrat in forum Gantry/Router Machines & Building
    Last Post: 17-08-2014, 03:46 PM
  3. Milling mild steel
    By dudz in forum Machine Discussion
    Last Post: 16-02-2014, 01:31 PM
  4. Milling Steel?
    By Musht in forum Metalwork Discussion
    Last Post: 02-12-2012, 07:00 PM
  5. Cutting 1.6mm mild steel with a CNC machine?
    By HankMcSpank in forum Machine Discussion
    Last Post: 01-05-2012, 08:56 PM
