Page 3 of 3 FirstFirst 123
  1. #21
    Are you powering up the BoB from the USB input or a separate power supply? The reason I ask is that USB supplies a limited current and you might not have enough power to work the BoB and more than 1 resistor. You may remember that I recommended that you did not use the USB port on the computer to power the BoB !
  2. The Following User Says Thank You to cropwell For This Useful Post:
  3. #22
    Also saves the switches getting smashed by riding over the target rather than into end stops.
    Been there, done that
  4. #23
    No I'm using a separate 5v PS. The lights don't light up when it makes contact either. But when I put the Blue wire on the 12v ps with the + it's lights up brite
  5. #24
    I think we have the problem !
    The earth return paths are not connected. The blue wire from the sensor should be connected to the 0v (gnd) terminals on both power supplies and also (of course) to the 0v ground on the BoB. This is the most likely explanation of the symptoms.
  6. The Following User Says Thank You to cropwell For This Useful Post:
  7. #25
    cropwell
    I ran the brown + wire to the positive on the 12v transformer. Then I ran the blue - to the Ground on the 12v transformer and the BOB gnd then I put the black on the input signal and the switch lit up but wouldn't trigger. So I disconnected the blue just from the transformer to the BOB and it now works like it should. It's more sensitive and works great.
    So no transistors.
    Thanks Mike
  1. Proximity limit switch problems
    By davrich in forum General Electronics
    Last Post: 12-03-2018, 12:58 PM
  2. FOR SALE: Proximity sensors
    By Web Goblin in forum Items For Sale
    Last Post: 13-09-2014, 07:02 AM
  3. Proximity switch NPN or PNP
    By Matt81 in forum General Electronics
    Last Post: 19-04-2014, 10:38 AM
  4. Proximity Wiring Problem
    By Bruce in forum General Electronics
    Last Post: 13-01-2014, 06:21 PM
  5. Proximity Switches
    By kingcreaky in forum General Electronics
    Last Post: 23-10-2013, 12:30 PM
