    Any suggestions please for modestly priced software to calculate speeds and feeds.
    It depends on your definition of modestly priced but I use HSM Advisor and have found it to be excellent, you can run it as a free demo for 30 days before deciding whether to purchase,
    - Nick
    Hi Leadhead,
    there are two good priced ones that I use:
    Gwizard from CNCCookbook.com expensive but will allow you to buy a life long license
    And
    FSWizard: http://zero-divide.net/index.php?page=fswizard ( The website version is free but materials are limited)
    The latter also has an Android app that costs around £12.
    To be honest, I cross check between the two to be sure things do not go south.
    Some CAM programs will do the calculations for you too but again, double check.
    Regards
    George
    https://emvioeng.com
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Current Activity: Viewing Has been a member for 9-10 years. Has a total post count of 1,605. Received thanks 110 times, giving thanks to others 69 times.
    I use FS Wizard and happy with it for what I need.
    I found some of the others such as GWizard too complicated and with so many variables, easy to make a mistake.
    Once you find feeds / speeds that work for your setup, you will know what numbers to use if you cut the same type of material instead of a lot of variation.
    Thanks - I am working with FS wizard 30 day trial. When you get more deeply into it, the comprehensive contents are more apparent. Very impressive. Probably get my purse out of the attic and go for the subscription.
    George - All arrived thanks"
    I use the 3 Year Floating License Subscription of HSM advisor which includes the FS wizard for android. I still have to try the FS wizard though.
    I believe that's best for starters, as the program is constantly updated with better features. It has tons of features that help understand better whats happening while cutting, which i see as the main benefit.
    Most importantly with a glance i can see the trade off between material removal rate, spindle power for the cut, feed rate and depth and quality of cut. So i can adjust accordingly.
  7. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  8. #7
    Rye's Avatar
    Lives in Sheffield, United Kingdom. Last Activity: 16-02-2019 Has been a member for 6-7 years. Has a total post count of 50. Received thanks 4 times, giving thanks to others 0 times.
    At the moment I have a 6 mm 4 flute end-mill (broke my 3mm and still waiting for more bits to arrive). I need to cut a shape out of 4 mm acrylic, but I'm not sure the speed & feed-rates I'm using are correct(16000 RPM with a feed rate of 550). I've just had a go at the on-line FS Wizard and it looks fairly decent, but a little complicated - so I'm not sure if I'm setting it up correctly(it gave me 16000 RPM with FR 1623).
    What speed/feed rates would you guys recommend for cutting acrylic with a generic 6 mm 4 flute end-mill?
  1. Feeds and speeds
    By dudz in forum Tool & Tooling Technology
    Last Post: 26-08-2013, 11:42 AM
  2. Engineering Calculators - speeds, feeds, torque, etc.
    By birchy in forum Machine Discussion
    Last Post: 16-06-2013, 01:42 PM
  3. Speeds and feeds deep drilling
    By Razorab in forum Sieg Milling Machines
    Last Post: 10-02-2013, 09:00 PM
  4. Advice needed on feeds and speeds!
    By lateAtNight in forum Machine Discussion
    Last Post: 14-11-2012, 12:47 PM
  5. Speeds and Feeds
    By Web Goblin in forum Tool & Tooling Technology
    Last Post: 20-09-2012, 01:38 PM
