    Yep, used to see it a lot years ago.
    White spirit any good?
    Kerosene
    yes but where can you buy it?
    Most Farming or heating fuel suppliers will stock it. . . . It's basicly low grade Diesil.
  5. #15
    ok, thanks, I gather we are talking mostly paraffin in the mix - 10% oil or more?
  6. #16
    I have one of those misters as in post #1, I am going to try it with a solenoid valve to pulse the air, using an Arduino to control it via a relay, so I can experiment with pulse and space times. It won't be until I have built my machine though, later this year.
  7. #17
    That would likely work ok, but set the jet in the nozzle so that it makes droplets not mist, will need to pressurise the fluid container as well.
  8. #18
    Well I made a Fog-Buster style unit and it does a pretty god job of fogging the shop up :(
    What do we need to do to it to stop it fogging and start it splattering?
    I'm using a 0.6 mig tip, maybe too small? might run a drill up it and see what happens, It also only works wit two pressure regulators - the fluid must be set higher than the air blast.
  9. #19
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Dave how have set it up. Did you see the dxf post #6 I use one reg on the compressor and one into the container. You do need a needle valve as well.
  10. #20
    Different shape but essentially the same, I followed dimensions I found online, 2.2mm through-bore with 1mm fluid bore, I have a flow control on the fluid inlet, one regulator on the fluid feed and one on the air feed.
    I think the nozzle is too small at 0.6mm, I will drill out to 1mm and try that - it should reduce air velocity and increase droplet size hopefully.
    Edit
    Just been looking at the Original Fog-Buster web site an they have no nozzle at all - just a plain tube so I might just cut the nozzle off and try that.
  1. Coolant, I am not sure which one to go with.
    By suesi34e in forum Swarf & Chip Management
    Last Post: 17-10-2015, 07:13 PM
  2. My Coolant System
    By Tenson in forum Swarf & Chip Management
    Last Post: 08-04-2013, 01:59 PM
  3. Washing Machine Pump Coolant System
    By Lee Roberts in forum Electronic Project Building
    Last Post: 05-05-2012, 01:30 AM
  4. coolant
    By luke11cnc in forum Machine Discussion
    Last Post: 11-02-2012, 01:17 PM
  5. Potential project opportunity
    Last Post: 11-09-2010, 12:44 AM
