    Hi!!
    MY first post. For many years I have been thinking of buying an CO2 Laser Cutter. The ready to use chineese cutters range from 900-3000gbp
    have been looking for an 5030 or 6040 machine. But have been reading alot they are unstable and no support after ordereing from China. Even they promise good service and support.
    So I will not go that route.
    So I was thinking, maby I could build a CO2 laser instead, with quality parts ang get a more stable and better laser cutter.
    Will use the CO2 for cutting up to 4-5 mm of plywood and 4-5mm of acrylic sheets. Also do engraving into theese.
    Maby one of theese rails will do the trick? :
    http://www.aliexpress.com/store/prod...244576102.html
    or http://www.aliexpress.com/store/prod...037540272.html
    i just need a 6040 system complete with head. Price is around 700-800gbp for the kit
    need to add:
    motors + driver
    lasertube 50 or 60w + psu
    optics
    dsp system awc 708 lite
    wires
    any thing else ?
    And build and case around the whole machine
    My question is, what is the recommended of
    Servo or stepper based motor?
    lasertube + psu ?
    Thanks for all reply :D
    Regards
    Palmar
    If you are cutting plywood you need to pump air down with the beam so the tarry gungy horrible smoke cannot get back on to your lens rendering it opaque and destroying the surface coating.
    The 6040 I got had a particularly naff fume extraction, a vague suck somewhere at the back, sudden steps in the ducting, no particular air inlet to guide or encourage the flow.
    The driver board and ghastly dongled Chinese software, open frame high voltage PSU scarcely justified the enormous amount of case set aside for them. Every expense had been spared.
    What it really needed was a water flow/temperature measure to stop me firing up the tube should the flow stop for any reason.
    If making your own, remember that everything below the beam wants to scatter light, not reflect
    Thanks for the reply.
    I will add a waterpump and a exhaust system + an air compressor for the head.
    I think a knife or
    honeycomb table will do the trick for no reflection of laser
    Nema 23 motor with 8mm shaft... but there are many of theese, different types... any that is recomennded for usage with a co2 laser and drivers
    Is it best to use dual shaft motor in Y axis?
    Will this do:
    Nema 23 motor for y axis
    • Step angle: 0.9 deg
    • Step per revolution: 400
    • Phases: 2
    • No. wires: 4
    • Current: 2.1A
    • Holding Torque: 0.9 N.M (127 oz*in)
    • Dual Shaft: 6.35mm in diameter
    • Dual Shaft length: 21mm
    • Inductance: 2.5 mH
    • Phase resistance: 1.8 ohms
    • Detente torque: 400 gcm
    • Rotor Inertia: 280 g-cm2
    • Weight: 0.6KG (1.4lb)
    • Length: 54mm
    The 6040 uses 200 step NEMA17 motors which are really zippy at 12V.
    There are no cutting forces, you really want to keep this as light as possible, especially if you want to scan a cross hatch engraving.
    I see. What about the step angle?
    I see there are 0.9, 1.2 and 1.8 angle.
    Should I go for an nema 17 also for the x axis ?
    regards
    Sorry cross purposes, I am trying to do too much and, apparently, failing miserably
    I am talking about the cheap Chinese laser, you are talking about converting a cheap Chinese router table in to a laser
    Please ignore everything I said
    hehe
    I have ordered the rail kit from mjunit Link here want to build co2 laser cutter/engraver from scratch :) I think that is better than ordering theese systems.
    Regarding the motors and drivers, I am a bit confused... There are a sh*tload of different nema 17 and nema 23 motors.
    They recommend nema23 motors since they have 8mm shaft. And the kit contains 8mm couplings and mounts for nema 23. But I am lost here...so many motors to choose from.
    What do I need to look after regarding motors and drivers?
    I would be gratefull for any tips regarding motor + driver :D
    Just received the parcels today. Well packed.
Name:	Skjermbilde 2015-11-10 kl. 17.41.05.png
ID:	16503Click image for larger version.
Name:	Skjermbilde 2015-11-10 kl. 17.41.14.png
    Here is layout
Name:	Skjermbilde 2015-11-10 kl. 17.43.59.png
    Will build a frame of aluminum extrusions 2020 and 2040.
    More later..
    PS.
    Any tips regarding motors + drivers? ;) It has 57mm mounts.
  1. Thinking about new CAD / CAM
    By Tenson in forum CAD & CAM Software
    Last Post: 13-09-2015, 10:18 PM
  2. Thinking of buying one of these little things
    By Hopey in forum Marketplace Discussion
    Last Post: 19-05-2015, 10:44 PM
  3. Thinking of building a 3d printer.
    By Jester in forum 3D Printing Machines
    Last Post: 24-04-2015, 08:23 PM
  4. Replies: 2
    Last Post: 20-04-2014, 05:19 PM
  5. I'm thinking of bidding on a lathe , what do you think it is worth ?
    By Fivetide in forum Marketplace Discussion
    Last Post: 22-09-2012, 10:50 PM
