23-06-2009 #23
It's a combination of the current through the coils, coupled with the number of turns (ampere turns in fact). It's a fine balancing act at that too.
Too many coil windings = too high an inductance, which means the coil presents resistance to higher frequencies feeding into it. The higher frequencies are the thinner strings, less ferrous material in them, so they actually need more drive
Too few windings = not enough magnetic force presented at the strings...only way to compensate is to cranck the current up, but that saps the battery.
Re round vs square coils. Square would be better (as it goes, I'd already considered them...in fact, you wouldn't believe the amount of McSpank Grey Matter processor 'cycles' I've dedicated to this little project!), but my simple coil winder (a drill chuck) cant cater for winding anything other than circular shapes! In fact longer rectangular coils would be better still...slightly overlapping one another so no dead spots when bending strings etc.
Not sure I fully grasp what you're getting at when you say (re square bobbins) "drill them to suit the size of the magnet" nor how could this proposale "reduce the height" .....I'm all ears, could you put more meat on the bone?
RFQ: Require small Stainless steel buckles machining- can you help please ?
By Gasgasbones in forum Projects, Jobs & RequestsReplies: 0Last Post: 15-05-2013, 06:47 AM -
How do I get this widget made (a small rectangular bit of 1.6mm mild steel)
By HankMcSpank in forum Marketplace DiscussionReplies: 25Last Post: 03-05-2013, 09:31 AM -
RFQ: Very simple small part
By Shinobiwan in forum Projects, Jobs & RequestsReplies: 5Last Post: 11-01-2013, 01:02 AM -
BUILD LOG: small mill for machining steel. Max spend £500 including computer
By Andrew Wilding in forum DIY Mill Build LogsReplies: 44Last Post: 20-07-2012, 03:46 PM -
RFQ: Request: 200 units of a small part
By craynerd in forum Projects, Jobs & RequestsReplies: 1Last Post: 13-02-2012, 10:25 AM
