Page 2 of 2 FirstFirst 12
    Quote Originally Posted by uli12us View Post
    I have downloaded the additional manual for the Enc Box. There are 3 Encoder inputs and this part should run with the IP/M Box as well. What can I do with the third Encoder? Or better, is it possible, to connect 2 enc boxes to a IP/M? Than I had 6 encoder inputs 1 for the spindle and 5 for all the axes.
    I believe the IP-M doesn't support the Enc module.? This may have changed with new Plug-ins but Best firing Cslabs email asking before buying.
    I thought, you have already tested, if the enc box is compatible.
    At the moment, I'll better try to get the machine running with a Mesa 7i76e that I have already here. That board have all in it what I can do with IP/M + enc + mpg + additional IO.
    It have as standard 5 S/D, 1 analog out, 1Encoder in, 32 DI, 16DO and from the DI, I can use 2 ports for a Mpg and another 2ports for analog in for feed or speed rheostat. Additionally I can add 2 other boards with similiar capabilities and to all this boards each a easier Board with additional IOs
    But for a further Project, it seems good to use a board, that don't have more in it, than what is needed.
    Mach3 as well seems a lot easier than Lcnc but is payware.
    Don't know why you'd think that because I've never mentioned testing Enc mod on any controller.?
    If you have Mesa card then it's a no brainer to me go this route.!
    Assuming you are talking Heidenhain equipped Bridgeports I think all the controllers from the TNC150 forwards had the capability to add a forth axis. What you may not have is the relevant Bosch servo drive card to drive the 4th axis servo.
    I have a Beaver Partsmaster with a Heidenhain TNC 355 controller. I've added a 4th axis to this machine by using a Bosch servo card from a Bridgeport Interact. It works well - I've even recently got the FeatureCAM post processor to let me engrave text on the outside of a cylinder with it :)
    I've a build thread on another forum, but I'll have to check with the mods if it's ok to link to it, as I know some forums get a bit shirty about that :)
  5. The Following User Says Thank You to AndrewMawson For This Useful Post:
  1. bridgeport
    By kingcreaky in forum General Discussion
    Last Post: 08-07-2015, 07:11 AM
  2. FOR SALE: bridgeport interact 4
    By cutter23 in forum Items For Sale
    Last Post: 01-07-2014, 11:47 AM
  3. WANTED: 3 axis cnc wanted bridgeport size
    By franky in forum Items Wanted
    Last Post: 31-05-2014, 07:57 AM
  4. Bridgeport series 1 MDI / CNC tooling
    By drumsticksplinter in forum Milling Machines, Builds & Conversions
    Last Post: 08-03-2013, 03:47 PM
  5. Bridgeport Conversion
    Last Post: 08-08-2011, 07:11 AM
