    hi all , just finished building my 1st 1500x 1500 ox and in need of some advise . im using CNC xPro Controller V2with grbl panel and ive run some pen drawing files with it
    but what ive noticed is that the one y axis stepper seems to be out of sync ( goes in correct direction ) but doesnt seem to move in time with the other resulting in like a twisting as you look across the x axis ? any help would be appreciated !!!!
    many thanks in advance
    Don't know anything about this controller I'm afraid has to be honest I feel they are a bit micky mouse so would never use one.!! . . . But the common reason for losing sync with slaved motors will be similar across most controllers so then I'd suggest looking at things like axis Binding first. Then setup regards motor tuning of velocity and Acceleration.
    You don't mention any setup details regards speeds etc so hard to tell but the fact this controller uses built in drives and only runs from 24v shows me you will be limited to how fast the machien can run so you may well be just expecting too much from it and have it over tuned.? This is the most common cause of missed steps which is what is causing your racking issue.!
  1. NEW MEMBER: Hi there CNC Newbie
    By Jester in forum New Member Introductions
    Last Post: 04-01-2014, 07:22 PM
  2. NEW MEMBER: A CNC Newbie!!!!
    By TCPLisa in forum New Member Introductions
    Last Post: 28-12-2013, 06:57 PM
  3. NEW MEMBER: Newbie Here (sorry)
    By graysclassics in forum New Member Introductions
    Last Post: 04-07-2011, 08:44 AM
  4. NEW MEMBER: Newbie
    By manofgresley in forum New Member Introductions
    Last Post: 05-06-2011, 05:31 PM
  5. few qs for a newbie
    By oadamo in forum CAD & CAM Software
    Last Post: 31-12-2010, 02:36 PM
