Page 2 of 2 FirstFirst 12
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 2 Weeks Ago Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Or you could scan or photograph it, resize the image appropriately, then import the image into a CAD program, from there it's quite quick to create an accurate drawing,
    - Nick
    Sounds feasible
    Any free cad that does this ?
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
    Draftsight does, its what I use to do drawings of RC planes.
    Neil...
    Build log...here
    Good to know there's a freebie option, I use BobCAD-CAM V25 for 2.5D, 3D & 4-Axis stuff so I bought the art package with a view to engraving work, it turned out to be of more use for 2D part replication ;-)
    - Nick
    I looked into the same thing a while back as I wanted to get an RC plane plan and put it on a surface and trace over the outlines etc with the mouse/puck. I remember back in the late 80's early 90's being at uni and using a tablet and puck for cad....on a Commadore 64. There are tablets out there but as been said their blinking expensive!
    I remember something similar in the 80's, a bloke I know spent a bundle of money on a vinyl cutter and computer[they will never catch on].
    I never took much notice of it, I was there when he did a van for a local motorbike shop; he drew a logo free hand with pencil and paper, then he went over it with a thing with a lens with cross hairs. I think he had to press a button at points and it created it on the screen.
  5. #15
    Time, and software has moved on. With the quality of digital imaging now available, and with the advent of packages with a good "Trace" function capable of generating vector outlines from bit-mapped images, the time of "digitising tablets" for accurate generation of technical drawings is well past it's sell-by date.
    Starting with a scanned image or photograph I use Photoshop for bit mapped image sizing, manipulation and processing then Illustrator for vinyl cutting vector art generation or Bob-Art for machining jobs.
    The only potential problem when photographing parts is distortion of the image caused by short focal length lenses, and/or having the focal plane too close to the object, by using at least a 50mm lens with the focal plane at least 1m away for parts up to 100mm length the results are good. For larger parts hanging on a wall and using a telephoto lens from longer distance would make sense.
    - Nick
