Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by eljainc View Post
    The Muppet show....love it!!
    Anyways, the wood prototype is basically that...a prototype, to prove that the part can be made. The aluminum part will basically "hug" the outside of a round metal pot
    which will allow the other side to conduct heat from a peltier cooling/heating device. That is the reason for the curved part. I somewhat agree with you regarding the vertical mill and using a boring bar. We just cannot visualize it. We do have a Grizzly Mill....with indexing: G0619 6x21 vertical mill. We've never done anything with a boring bar...an idea to possibly try. Our finish required is not super important...just can't have a real rough finish or the part will not have great contact with the pot and the conductivity will not be as efficient.
    In that case I would definitely go with a fly cutter / boring bar.
  2. #22
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 19 Hours Ago Has been a member for 9-10 years. Has a total post count of 786. Received thanks 96 times, giving thanks to others 176 times.
    Hi
    As per Rufe0
    To be honest for the application intended the boring bar option is the only way to go, you can then offer up the pot to make sure you are getting a full mating surface adjusting cutting radius to suite.
    Regards
    Mike
  1. RFQ: Small aluminum milling/water cutting
    By Harry Hills in forum Projects, Jobs & Requests
    Last Post: 02-11-2014, 01:54 AM
  2. NEW MEMBER: where to buy aluminum extrusion
    By troyboy1 in forum New Member Introductions
    Last Post: 21-07-2014, 01:52 PM
  3. symmetrical hart shape in vectric v carve pro
    By cockneyrebel in forum Vectric
    Last Post: 24-02-2014, 02:55 PM
  4. Flexible Stainless Steel pipe that holds its shape?
    By Fivetide in forum Marketplace Discussion
    Last Post: 14-02-2013, 07:35 PM
  5. tool for aluminum on uk
    By edgas10 in forum Tool & Tooling Technology
    Last Post: 26-04-2011, 11:23 AM
