Page 3 of 3 FirstFirst 123
  1. Also an option?
    http://www.ebay.co.uk/itm/colchester...3D231773982948
    Not sure how Id collect it however...
  2. #22
    It's your money, Chaz, so it's very easy for us lot to give advice! However, that link in your last post looks to me a better option than the original one, mainly because it's better equipped. Transport could be an issue, of course, but that's going to be the case for most of these unless they come from a dealer with their own transport. I had my (2800lb) lathe fork-lifted on to a hired flat-bed Transit and arranged for a friend with tractor and front-loader to take it off for me.
    Again, because it's all got a bit rambling and confused, my own preference would be for a decent second-hand machine rather than a new Warco. Purely my personal choice, and I'm happy that I went that way, even though my machine still needs a bit of work to get it working absolutely 100%.
    A 4KW VFD should be enough to drive any of these machines, as long as you can rewire the motors as 240V rather than 415V (probably wired as 415V as standard). I'm assuming that your VFD is 240V 3-phase; chances are that none of these lathes are going to have bigger than a 3HP or so motor which translates to 2.2KW, well within capacity.
  3. #23
    I have never seen a VFD in 240V with more than 2,2kW. All above needs 415V. But, If you have a motor with 4kW and the power you need is only half of the motor is capable, you can use a 2,2kW VFD for it.
  4. #24
    If you were looking for someone to collect it, I would highly recommend Steve Cox (landylift) He delivers machines such as these every day, and makes a fantastic job of siting your machinery when he arrives at your premises. He got my lathe right into the position that it was going to live, and even gave me some help to get it all set up level.
  5. Quote Originally Posted by uli12us View Post
    I only have single phase 220V available @ 32 Amps.
    This is roughly 6KW, so should be able to drive 4KW with this ....
  6. Quote Originally Posted by needleworks View Post
    Thanks. That's useful.
  7. Thoughts on this?
    Looks very clean, low current price ....
    http://www.ebay.co.uk/itm/SMART-AND-...3D321939245505
  8. #28
    Just in case you actually want one - e.g. this: http://www.ebay.co.uk/itm/3KW-4HP-13...gAAOSwMmBVk81l
  9. Quote Originally Posted by Jonathan View Post
    I actually have the 5HP / 4KW version of that.
    http://www.ebay.co.uk/itm/UPDATED-VA...4AAOSwyQtVuzQb
  1. Laser for under 2000?
    By KevinC in forum Laser Machines & Building
    Last Post: 22-11-2015, 09:57 PM
  2. Sherline 2000 CNC Mill
    By cooliced in forum Sherline Mills
    Last Post: 12-01-2013, 09:22 PM
  3. NEW MEMBER: Hello from Staff 2000
    By Alex@staff2000 in forum New Member Introductions
    Last Post: 20-11-2009, 11:23 PM
  4. Mach 2 / 3 - Windows 2000/XP
    By teetat in forum Artsoft Mach
    Last Post: 10-07-2009, 01:47 PM
  5. Best cnc mill for under 1500-2000
    By xchipx in forum Milling Machines, Builds & Conversions
    Last Post: 05-03-2009, 07:42 PM
