    dudz's Avatar
    Lives in Bretagne, France. Last Activity: 20-05-2017 Has been a member for 4-5 years. Has a total post count of 256. Received thanks 1 times, giving thanks to others 50 times.
    I have a 4kw air compressor. 220v/380v rated
    I have wired the motor in delta. For 220v 3 phase.
    The Badge on the motor states RPM 2880 at 50 hz
    I have a 4kw VFD. Set at 50hz. This is giving me 1440 RPM. The single phase power input is 240V (France used to be 220v but is now 240v) . The VFD states it is drawing 5.2A
    Can I safely increase the HZ to bring up the Motor RPM ?
    3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle......"USB Breakout Board Interface 200KHz"....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
    dudz's Avatar
    Quote Originally Posted by dudz View Post
    Done....
    Found a setting on the VFD = PD144 Motor RPM Setting
    Sounds like a "pole changing motor" which often have complicated wiring connections, 2 pole delta may not be possible, need some of the boffins of the forum to comment.
    Std motors generally dont like 100Hz and would probably adsorb more than 4Kw anyway.
    dudz's Avatar
    Quote Originally Posted by johnsattuk View Post
    Already sorted but thanks for your input ! . Read above
  1. What to look for in an air compressor.
    By Philly in forum Tool & Tooling Technology
    Last Post: 27-04-2013, 10:02 PM
  2. Compressor specification for alu chip blower
    By Saracen in forum Machine Discussion
    Last Post: 12-01-2013, 08:17 PM
  3. Has my air compressor died?
    By Jonathan in forum General Discussion
    Last Post: 14-10-2012, 11:08 PM
  4. Which air compressor?
    By newtoid1986 in forum General Discussion
    Last Post: 12-12-2011, 03:07 PM
  5. Air compressor - faulty, how do I get the motor out?!
    Last Post: 26-10-2009, 10:33 AM
