Thread: Mach 3 ports and pins problems,
04-04-2017 #9
Tom Cslabs doesn't recongnise Dir Low active for changing motor direction. None of the port/Pin are used either so set to Zero. If want to swap axis the you do it in the Cslabs Plug-in and re-assign channels. By default X = Ch0 Y=ch1 Z=ch2. So if want to swap X & Y then just set X=ch1 Y=ch0. No wire swapping required.
You would do this if view machine from front so X runs across gantry and Y along the length. This will make it display correctly or make sense inside mach.
Go to Config/Homes/limits and change the Reversed option. You may have to change Home negative as well so goes right way when homing.
If keys don't do what you want then go into system hot keys and change the jogging keys.
Also if setup Softlimts and you change axis channels you'll need to change these as well.Last edited by JAZZCNC; 04-04-2017 at 05:50 PM.
Parallel ports problems
By Cnc many in forum Computer HardwareReplies: 28Last Post: 16-12-2015, 01:59 AM -
circle cutting mach 3 problems help please
By millmateuk in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-06-2013, 07:04 AM -
problems with mach or windows
By johngoodrich in forum Computer SoftwareReplies: 2Last Post: 02-03-2012, 07:23 PM -
ports and pins for system4
By Dan Brown in forum Motor Drivers & ControllersReplies: 2Last Post: 18-01-2010, 06:37 PM -
Ports and pins help ? mach 3
By xchipx in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 19-04-2009, 12:45 PM
