Page 15 of 15 FirstFirst ... 5131415
  1. #141
    These are in the UK and not too bad on price Chalon's RT18 DIN fuse holders I've found that Chalon are good value and you get good service from them, or at least I've had good service...
    Yea I can second that, Chalon are just down the road to me in Haydock and as Neil says great service all round, I selected these RT18's for an up coming CAB build too and they look to be just the job, they also have an Chalon-Components-Ltd eBay Shop, as you would expect though things cost more there, like the fuse's for these holders :).
    .Me
  2. #142
    Hi guys. sorry for not keeping this log up to date (as progress has been on/off without much of a plan!!) but with all the help/support, finally managed to get this lump of steel moving!!
    https://www.youtube.com/watch?v=DxSn...ature=youtu.be
    Its quite a bit better than my first official cut, which was accidentally plunging 5mm into the bed whilst doing an "air cut". I guess if your as daft as me, the starting test should be "air cut WITH NO TOOL, ESPECIALLY NOT A BOTTOM CLEARING BIT!!"
    Attachment 20497
    Thank you everyone that helped, especially Dean and Clive for all of their patience! and again Dean for helping me out with the mounts and providing the code for the above
    Next lot of tasks include:
    - Building an enclosure/some sort of extraction to prevent this happening every run:
    Attachment 20498
    - Maybe filling this thing with sand as when you guys say the machine "starts walking", I always thought you were joking...but to my suprise it actually does!! X axis had just randomly stalled and when looking around, I saw the machine had "walked" back few inches and was rubbing the pulley against the wall!!
    Attachment 20499
  3. #143
    Hi guys, was wondering if you could help me out with compressors again please? As my old one is not going to be fit for longer term usage (ie, more than a day ), I was looking into getting a new one. This is the one i'm looking at from a local warehouse: https://www.jtf.com/air-compressor-50l-2hp.html
    Reason being, it's covered by a years guarantee so won't be as bad if it does overheat. I know the specs are limited, but in general, what do you think? Suitable for CNC chip clearance? Cheers.
  4. #144
    Ok but noisy. If noise matters i would go for a piston pump and belt drive motor
  5. The Following User Says Thank You to Davek0974 For This Useful Post:
  6. #145
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 6-7 years. Has a total post count of 469. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    Bit of a bump - friend has just acquired this machine but having issues with seeing the images in this thread - Lee, don't suppose you're able to take a look?
  1. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. BUILD LOG: First steel diy CNC router build
  5. BUILD LOG: 7' X 4' Steel frame build
