07-03-2016 #16
Yes, spattery a bit more but if you can get it, its far cheaper than any pro mix and great for practising on. A little spatter on a job like this is not really that crucial i feel, I never had that much that it was a pain - its not like chalk and cheese.
+1 on the wire feed, this must be set right first off, as you said, too low will give a weld but damn, things will get hot and can lead to a large heat affected zone and distortion etc which can easily be avoided.
Current is pretty easy, if this is like 4mm box then any hobby welder in the 150-180A range will likely be on full-tilt, but getting the wire feed and motion speed right takes a little practice.
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
